So I've used VRT after using white wall cleaner ( from work ) to degrease the tires. Brown run off usually occurs on the tires when I use it. I've noticed that one the two brand new Michelins, the VRT stuck well, even after a second wash using the white wall tire cleaner. Still had vrt on the two new tires.
The back tires are older, same model Michelins. However, using the same method on yhe older tires, the VRT didn't stick well. It came off after a day or two, and wasn't there there at all when it came to wash time. Any suggestions?
JDrach
19 answers to this question
