PT3 Posted August 21, 2016 Share Posted August 21, 2016 (edited) Hey.... I used my Cyclo for the first time.... It seemed the product was drying up extremely quickly. So I found myself using DS and more product WAY more than I would expect. Thoughts? Edited August 21, 2016 by PT3 Link to comment Share on other sites More sharing options...
0 mbzamg32 Posted August 21, 2016 Share Posted August 21, 2016 Did you do one panel at a time? And for my experience I just used a little of the pcp with this product less is more. If it is getting hard to take out put some brilliant glaze on top and it should wipe away easily. PT3 and Tyler@Adams 2 Link to comment Share on other sites More sharing options...
0 ematt1212 Posted August 21, 2016 Share Posted August 21, 2016 (edited) . Edited November 23, 2016 by ematt1212 Ricky Bobby, PT3 and PHOKUS 3 Link to comment Share on other sites More sharing options...
0 Ls1transam Posted August 21, 2016 Share Posted August 21, 2016 I've had the same problem. You have to work in a really small area with the polish if working in high temps and humidity. Link to comment Share on other sites More sharing options...
0 PT3 Posted August 22, 2016 Author Share Posted August 22, 2016 Did you do one panel at a time? And for my experience I just used a little of the pcp with this product less is more. If it is getting hard to take out put some brilliant glaze on top and it should wipe away easily. Nice car! If you're talking about finishing polish drying up, try not to work it in too much. Finishing polish has little abrasion so theres no need to let it flash off the paint or work it in. I treat it like a glaze that need to be worked in a little more. Then wipe off right away before it gets dry. If you're having this problem with Correction Polish your pad might have too much product built up in the pad. I've had the same problem. You have to work in a really small area with the polish if working in high temps and humidity. Thanks guys! I was working in a 2'x2' spot. But....it was super hot and humid. Though, the sun was setting and behind the trees (FYI) Link to comment Share on other sites More sharing options...
0 The Guz Posted August 22, 2016 Share Posted August 22, 2016 it was super hot and humid. This plays a factor Thanks guys! I was working in a 2'x2' spot. But....it was super hot and humid. Though, the sun was setting and behind the trees (FYI) You were working outside? Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted August 22, 2016 Share Posted August 22, 2016 This plays a factor You were working outside? ^x3 - didn't you build a garage last year Phil? Link to comment Share on other sites More sharing options...
0 PT3 Posted August 22, 2016 Author Share Posted August 22, 2016 This plays a factor You were working outside? ^x3 - didn't you build a garage last year Phil? Hey guys.... I didn't 'build' a garage per se. I just renovated my 1-car garage. I could have done it inside the garage.... but the temp/humidity would have been the same. And since the sun was setting I didn't have to worry about direct sunlight while being outside. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 22, 2016 Share Posted August 22, 2016 If you are working in the sun you will experience your polishing drying out, try using less polish and a little more DS. And if possible find some shade to work in. PT3 1 Link to comment Share on other sites More sharing options...
0 PostalTwo Posted August 22, 2016 Share Posted August 22, 2016 Hey guys.... I didn't 'build' a garage per se. I just renovated my 1-car garage. I could have done it inside the garage.... but the temp/humidity would have been the same. And since the sun was setting I didn't have to worry about direct sunlight while being outside. But if your car was outside throughout the day the paint would have been at least warm if not still hot Link to comment Share on other sites More sharing options...
0 The Guz Posted August 22, 2016 Share Posted August 22, 2016 But if your car was outside throughout the day the paint would have been at least warm if not still hot That is what I was getting at. Especially with black paint. It doesn't take long for it to get warm or hot. PHOKUS, PostalTwo and PT3 3 Link to comment Share on other sites More sharing options...
0 PT3 Posted August 26, 2016 Author Share Posted August 26, 2016 If you are working in the sun you will experience your polishing drying out, try using less polish and a little more DS. And if possible find some shade to work in. But if your car was outside throughout the day the paint would have been at least warm if not still hot That is what I was getting at. Especially with black paint. It doesn't take long for it to get warm or hot. Thanks guys. Totally understand. Man there are so many aspects that need to be considered. Link to comment Share on other sites More sharing options...
PT3
Hey....
Thoughts?
Edited by PT3
11 answers to this question
