buffalobob920 Posted October 5, 2016 Share Posted October 5, 2016 I should know this but how do you wash Adams microfiber cutting pad Thanks Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted October 5, 2016 Share Posted October 5, 2016 I just clean it the same way I clean my other pads, APC and water. Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted October 5, 2016 Share Posted October 5, 2016 I pre soak in some apc and water until im ready for the cleaning. Then I hit the lad with a couple squirts of apc and rub in my fingers once I have worked the apc in i rinse the pad until water is clear coming out. Then it's air dry and store for next use Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted October 5, 2016 Author Share Posted October 5, 2016 Ok thanks guys for the advice Link to comment Share on other sites More sharing options...
0 mc2hill Posted October 5, 2016 Share Posted October 5, 2016 Same as Daniel and Jim, clean with APC, then scrub it on Grit Guard to remove remaining polish. Rinse well, then place on the GG face down to dry. Link to comment Share on other sites More sharing options...
0 SumBeach35 Posted October 5, 2016 Share Posted October 5, 2016 Another way to clean it is to hit it with some MBR, let it soak then rinse with water. Personally, I have been washing all of my DA pads in the washer on the pulsed or delicate mode then placing them backing plate side up to dry. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted October 5, 2016 Author Share Posted October 5, 2016 Thanks kevin I always think about putting them in the wash always worried about ruining them but if it works maybe I will try it I see your a sabres fan so am I and bills fan Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted October 5, 2016 Share Posted October 5, 2016 I'll add that I use the Pad Conditioning Brush to scrub the microfiber face while I'm cleaning mine in my laundry room sink with water and APC. SumBeach35 1 Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted October 5, 2016 Author Share Posted October 5, 2016 One other question on the foam pads what is the best way to clean them do you use the pad cleaning brush on them to Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted October 5, 2016 Share Posted October 5, 2016 Yep, I will spray them down with some APC, let it soak for a few minutes, and then use my fingers and thumbs to massage the polish out while running it under water. The Pad Conditioning Brush can be used to gently scrub the foam to help remove the polish more easily, just make sure not to start tearing the foam with the firm bristles of the brush. Link to comment Share on other sites More sharing options...
0 SumBeach35 Posted October 5, 2016 Share Posted October 5, 2016 Thanks kevin I always think about putting them in the wash always worried about ruining them but if it works maybe I will try it I see your a sabres fan so am I and bills fan so far with how little i have polished my stable, i feel washing them in the washer is okay. I eventually want to get a pad washer system to minimize residue build-up during polishing and help clean them. Been reading and watching quite a bit about residue management lately and while you can do it without a pad washer, just seems like a useful tool. I am a Sabres fan but I don't follow football that much anymore. Link to comment Share on other sites More sharing options...
buffalobob920
Thanks
10 answers to this question
