crazyfingers Posted October 26, 2021 Share Posted October 26, 2021 Fairly new here, looking to apply Graphene to my 2021 C8 before I put her away for the Chicago winter. Is there an optimal temp/ humidity range for application? mc2hill and RayS 2 Link to comment Share on other sites More sharing options...
0 Rich Posted October 26, 2021 Share Posted October 26, 2021 Full Graphene or Graphene Spray Coating? Link to comment Share on other sites More sharing options...
0 falcaineer Posted October 26, 2021 Share Posted October 26, 2021 50°F+, and lowest humidity as possible are ideal. For reference, we applied the Professional Grade Graphene Ceramic Coating during the Shine Academy class this past weekend in 62°F and 21% humidity and it worked perfectly. Lower temperature and humidity allows the coatings to take longer to flash and ultimately be easier to work with. Link to comment Share on other sites More sharing options...
0 Trap Posted October 26, 2021 Share Posted October 26, 2021 (edited) I have only done it once, but when I did the temps we're in low to mid 60's. Humidity was low. Found it very easy to work with. Watch the videos and just make sure it doesn't cure to long. Took me about 4 hours to coat the car after it was prepped. Make sure you prep it properly, was the main advice I was given. I used the Advanced Graphene Coating. Do have a little car envy on that one. Edited October 26, 2021 by Trap Link to comment Share on other sites More sharing options...
0 crazyfingers Posted October 26, 2021 Author Share Posted October 26, 2021 9 hours ago, Rich said: Full Graphene or Graphene Spray Coating? Full graphene. Temps this weekend should be low-mid 50’s, but humidity might be a little high. Rich 1 Link to comment Share on other sites More sharing options...
0 falcaineer Posted October 27, 2021 Share Posted October 27, 2021 14 hours ago, crazyfingers said: Full graphene. Temps this weekend should be low-mid 50’s, but humidity might be a little high. Those conditions should be fine. crazyfingers 1 Link to comment Share on other sites More sharing options...
crazyfingers
5 answers to this question
