Posted (edited)
Hey guys! I was fortunate enough to receive the prototype pads that utilize a cordless drill as per the infinite generosity of our fearless leader Adam! I tested these pads on two spots on my car. The first scratch I've had on the car for as long as I've owned it. I have a feeling I took delivery of the car with this scratch on it and idiot me never saw it. The second scratch happened as a result of people probably not paying attention to where they are walking and brushed up against my rear 3/4 panel.
Culprit #1:
Culprit #2:
My car is absolutely filthy because the weather here in NYC is nuts. It will rain for three days straight and we'll be blessed with one gorgeous day only to have more rain for another few days. Typical because I received the new foam gun and all those goodies two weeks ago and have yet to try it out. :willy:
But I digress. Anyway, I sprayed down the area on the edge of the hood with detail spray to make the area clean. I then misted the orange pad with detail spray and put some Swirl and Haze Remover on the pad.
I then went to town on that sucker. I was very careful not to use full speed on the drill as I did not want to screw my paint up. I maintained a steady speed and pressure and buffed it out. I noticed immediately that the middle of the scratch for the most part was gone but the edges still remained. Another interesting thing happened. The orange pad disintegrated a little bit and it rained orange fuzz for a few seconds. Here's a pic: note how torn up it got.
I went back over the scratch with some Fine Machine Polish on the white pad.
After wiping away the residue from the Fine Machine Polish I decided to try the orange pad again to see what else I could remove. On the second pass the middle of the scratch was invisible, but again the edges remained. I then repeated the step with the Fine Machine Polish on the white pad. After that, I whipped out the orbital buffer. I hit that scratch with the orange pad (SHR) followed by white pad (FMP) and concluded with black pad with (MSW). Here is what that scratch looked like after I finished playing around:
In conclusion I am happy with the result. The problem is that the edges of that scratch were actually chipped so the only real way to make that disappear is to fill it with some touch-up paint. Also I'm a tad bit surprised that the orange pad disintegrated on me a little bit. Not sure why this happened but ok lol.
Onward to the rear 3/4 panel! I basically repeated the exact same process as I mentioned before except I only used the cordless drill for one pass with the orange pad instead of two. Here is what that scratch turned into:
Perfection! I only put my finger there to show you where the scratch was. Again, I want to thank you Adam for hooking me up with these pads. Shine on everyone! :thumbsup:
Edited by JJ1o87
Posted
i have a product that is the same thing but it is a ball not a pad and it did the same thign disingerated buti think alot more than what you said this thing was flying everywhere. :pc:
Posted
Dude!! You need to resize your pics!
Good write up. I haven't had a chance to try them yet, but I appreciate you showing us the ropes. Looks great.:cheers:
Posted
It looks like a bit of 3000 grit and water would have helped reduce the scratches to the point where the pad and SHR would have worked a bit quicker. I ran into this the other day and used the 3000 grit and then the PC and it worked great.
The end result was the same so congrats!
Posted
Thanks man - I don't have the testicular fortitude to attempt wet sanding yet tho!
Posted
It's A LOT easier than most think...
It looks like someone opened the hood with the wipers up by the looks of that scratch but it's hard to tell on the web... lol
Chris
Posted
^ probably i think it was on there when he got it for some reason....
also bro u forgot to mention that the pad on the drill creates heat!
Posted
Especially on a BLACK 2009 Charger :cheers:
I've been trying to find some old vehicle to try it on.
Posted
Especially on a BLACK 2009 Challenger :cheers:
I got scratch or two I would like to try this on.
Posted
hah, thanks for the correction!
Charger:
Challenger:
3057184437_3b3ce803a6.jpg?v=0
No comparison! :lolsmack:
Posted (edited)
Haha I totally know the difference. I have no idea why I said Charger. The Challenger is MUCH different than the Charger.
Edited by Superdutytd
Posted
Hey Jeff, thanks for the write-up! I'm also surprised the Orange Pad flaked away. Did you use any Detail Spray when polishing? :confused:
Sorry, and I'm going to send you a new Orange Pad in the mean time.
Thanks again for the write-up!
Posted
Absolutely, I always spray the pad down with detail spray before I put Swirl and Haze Remover on it. The interesting thing is that I used the yellow and white pad as well and they held up fine. So I'm assuming it was an isolated incident. Not sure, but the pad got a little torn up. Glad I could help you guys out!
Posted
Great to know, and that's something to look closely at in the future, and when we sell the Orange Pads, we may want to offer them in 2-Pk's.
Do you think that your Orange Pad is ready for the garbage Jeff?
We need to get this product combo dialed-in before offering it officially. Again many thanks for your input and write-up Jeff!:bow:
Posted
I would totally sell em in two packs. I'm not sure if its ready for the garbage, but if I were a customer that just bought that i'd be peeved to say the least lol. It probably has a few more uses left in it tho. Here's a pic of it after I cleaned it up with APC:
Posted
My orange pad actually split a bit on the side, it looks like someone took a razor and split the edge but it still works fine. (adam don't you dare try and send me a new one, I'll send it back :lolsmack:). I don't know if you could maybe make the orange pad just a bit more robust? Just an idea.
Posted
Well, I tried my pads with the drill today. I don't have the MSW or the FMP, so I just used the Swirl and Haze Remover and Buttery Wax.
I had a major scratch on the left headlight cover. A pinecone dropped from the tree and hit it. The white dots are just dust.
So I hit it once with the S&H and the orange pad, then once again with the white pad.
I repeated the process three times total,
then buffed it with the black pad and Buttery wax.
It's not perfect, but it's sure not what it was. I still have to detail the whole car and get rid of the residue and swirls, but it looks much, much better. I tried the process on some hairline scratches that I've had on the door and roof of the Vette for almost 6 years from a piece of carpet that fell from the rafters. I thought they'd never come out, but they're nearly invisible now.
I had no problem with any of my pads. The orange pad looks fine. But this is a pad I just got about two weeks ago, so if there were any changes made since Jeff got his, that could explain a lot.
Posted
Hey Rich, Did you try something a bit more abrasive than the SHR? I think a buffing compound would make quick work of it. Like a 3M Finesit(sp?)??
Chris
