Ok all of you Adams rep's out there, this is for you. I started with the Buttery Wax when I first began using Adams, some two and a half years ago. Then when the new Super Machine Wax was released, I changed over to it, because I had a PC buffer and it seemed like the way to go. I could not be happier with the results I received from both products.
Now for my question, what benefit will or can I expect to see if I use the new paste wax instead of the Super Machine Wax? Also is this product as easy to use (apply & remove) as the Buttery Wax or the Super Machine Wax? My car is not a true daily driver and although now that I am retired, it is being used more then when I worked. It is garage kept and covered also in the garage.
TR6speed
Thanks
19 answers to this question
