teky929rr Posted January 7, 2010 Share Posted January 7, 2010 Unfortunately we have idiots in this world, but my coworker's 2010 Dodge Journey was recently vandalized with spray paint. Any suggestions on getting spray paint off the car? Link to comment Share on other sites More sharing options...
Chewy Posted January 7, 2010 Share Posted January 7, 2010 I believe they sell a graffiti remover... I was thinking Auto-Zone has it... I found this: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100197013&langId=-1&catalogId=10053&ci_src=14110944&ci_sku=100197013&cm_mmc=shopping-_-googlebase-_-D24X-_-100197013 Chris Link to comment Share on other sites More sharing options...
Chris@Adams Posted January 7, 2010 Share Posted January 7, 2010 If its not to heavy you could use Adams Clay Bar. Adam's Detailing Clay Bar Adam's Detailing Clay BarCatalog No: A001Price: $24.95 The modern clear coat finish needs to stay clean to look good and remain healthy. The quick and easy secret is Adam's Detail Clay! Link to comment Share on other sites More sharing options...
Team Adam's Posted January 7, 2010 Share Posted January 7, 2010 Yea, depending on the severity of it you might be able to remedy the problem with the claybar. It will depend entirely on how heavy the spray is, how long its been on there, and what kind of paint it was. Link to comment Share on other sites More sharing options...
teky929rr Posted January 7, 2010 Author Share Posted January 7, 2010 Thanks! Link to comment Share on other sites More sharing options...
b_pappy Posted January 7, 2010 Share Posted January 7, 2010 You want to use the mildest method you can to remove the damage. Years ago I resorted to Lacquer thinner (not paint thinner) to remove graffiti from a car. If you go that route you'll have lots of polishing ahead of you, but the thinner should not damage the cured factory paint. Always test in a small inconspicuous area first. Bruce Link to comment Share on other sites More sharing options...
Rich Posted January 7, 2010 Share Posted January 7, 2010 I've actually removed road paint with just detail spray and a lot of elbow grease. But it sounds like you have a lot more than that. I'd try the clay bar and detail spray first, then go from there. Good luck. Link to comment Share on other sites More sharing options...
Junkman2008 Posted January 7, 2010 Share Posted January 7, 2010 I have always been able to remove spray paint with just a PC and some SHR. Quick and easy. Just don't leave it on for two years and expect it to come off. Link to comment Share on other sites More sharing options...
teky929rr Posted January 7, 2010 Author Share Posted January 7, 2010 Thanks again for all the responses. I'll pass it on. Link to comment Share on other sites More sharing options...
11chevz71 Posted January 7, 2010 Share Posted January 7, 2010 I would try any above. Link to comment Share on other sites More sharing options...
whiterp199 Posted January 8, 2010 Share Posted January 8, 2010 Good luck. Let us know what you did and how it worked. Link to comment Share on other sites More sharing options...
teky929rr
10 answers to this question
