Ok, I just received my new Adams Swirl Killer 15mm LT Polisher and I order it in the mystery box. It is replacing a Porta Cable that I purchased many years ago. Among other things (and I must admit I was more then happy with what was in the box) was the Blue Microfiber Cutting Pad. I have an second shipment due to day with the One Step Pad. So my question is first what pad would the experts suggest. I plan to do a strip wash, clay polish and then apply the Ceramic spray coating and then the boost to my wife's 2018 Equinox. It has some swirls that I would like to remove first. Second in the box was also the blue compound. I have always stayed away from compound but I do trust Adam to supply quality products. So which pad is the most aggressive. I was thinking to start with the least aggressive and if need be move up. I was planning to use the one step polish also to start with.
Final question, I do not plan to use the Ceramic kit on my Corvette, but with the hard clear coat that is on the C6 Corvette's is the compound to aggressive to do spot correct before moving to the correct polish?
TR6speed
3 answers to this question
