MikeNRA Posted October 22, 2011 Share Posted October 22, 2011 Any thought on the best way to deal with this scuff? --- I am here: http://maps.google.com/maps?ll=41.336743,-75.032647 Quote Link to comment Share on other sites More sharing options...
0 txredgt Posted October 22, 2011 Share Posted October 22, 2011 APC with a microfiber and if possible, let it soak as much as you can. Claying could also help but it may not be able to get it. I've had mixed results personally when trying to remove similar things. Quote Link to comment Share on other sites More sharing options...
0 Frid Posted October 22, 2011 Share Posted October 22, 2011 APC with a microfiber and if possible, let it soak as much as you can. Claying could also help but it may not be able to get it. I've had mixed results personally when trying to remove similar things. I agree. You can go back over after you get the scuff out with some SVRT. It will make it look as good as new. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted October 22, 2011 Share Posted October 22, 2011 If APC doesn't work try 3M Adhesive Remover! Quote Link to comment Share on other sites More sharing options...
0 07RS4 Posted October 22, 2011 Share Posted October 22, 2011 Toothbrush and APC, or try IPA. Quote Link to comment Share on other sites More sharing options...
0 dipolley Posted October 22, 2011 Share Posted October 22, 2011 If those fail, peanut butter. Rub creamy peanut butter on the problem area. The peanut oil will loosen it and the small bits of peanut and the sugar will act as an abrassive. Wipe off and clane with APC then SVRT. This works well for me with wax and polish on plastics as well. That looks like paint transfer from the bollards at the McD's driver thru. But worth a try. Quote Link to comment Share on other sites More sharing options...
0 Z71_Denali Posted October 22, 2011 Share Posted October 22, 2011 i had a similar scuff on my mirror, but not as bad. sprayed 100% APC on it, buffed and rubbed it down with a microfiber cloth, and dressed it with SVRT. the paint came off, just left a few minor scratches but the SVRT covered them up real nice! Quote Link to comment Share on other sites More sharing options...
0 MichiganSRT8 Posted October 22, 2011 Share Posted October 22, 2011 APC and clay has gotten off similar for me! Quote Link to comment Share on other sites More sharing options...
0 Doug123 Posted October 22, 2011 Share Posted October 22, 2011 If APC doesn't work try 3M Adhesive Remover! - the 3m Adhesive Remover may get it done if the milder methods don't work. Quote Link to comment Share on other sites More sharing options...
0 Fit08 Posted October 22, 2011 Share Posted October 22, 2011 Well, what is the outcome with the suggestions? Quote Link to comment Share on other sites More sharing options...
0 Jonathan. Posted October 23, 2011 Share Posted October 23, 2011 Just removed some like that from a smooth flat finish bumper, yours looks like its textured. I used, goo gone, go over it with many light light applications of the goo gone, rather then letting it sit, its extreme powerful. Get a disposable rag, apply the goo gone, in a light layer by dabbing it into the problem area. Allow it to sit for 10 seconds or so, then rub in a circlular motion for another 10 seconds, then remove it by spraying it down with APC or isopropyl. Repeat until scuff is gone. Then, apply SVRT and your goo to go. p.s Don't let goo-gone sit on the plastic for a long period of time. Quote Link to comment Share on other sites More sharing options...
MikeNRA
10 answers to this question
