Just got finished with my first Adam's-style wheel and wheel well cleaning.
One wheel at a time, I...
1. Blasted off the dirt with high pressure water
2. Sprayed the wheel and caliper down with GWC
3. Sprayed the wheel well and tire down with APC
4. Wetted my fender brush and scrubbed wheel wells and tires
5. Wetted my wheel brush and gently cleaned the wheels
6. Used the power stick on the barrels
7. Used the lug brush on the lugs, caliper, and valve stem
8. Rinsed wheel/tire/wheel well thoroughly
9. Dried with leaf blower
After all this, I dressed the tires with SVRT and used the Undercarriage Spray in the wheel wells. The wheels and wheel wells have never looked better, but...
After cleaning all four wheels/wheel wells on my Challenger, I had used nearly 1/3 of my 36oz APC. Does that seem excessive? It has the foaming spray head, which worked (created foam), but seemed to go through an inordinate amount of product. I did not feel I went crazy with the APC, it just took a lot of product to get on all the surfaces...
Would I be better off with a non-foaming spray head? Should I dilute it? 10-12oz of cleaner per wheel cleaning seems excessive.
mattpiper
25 answers to this question
