07 z-oh-6 Posted February 12, 2012 Share Posted February 12, 2012 from glass? I would think so, but not sure. FYI, I don't want to remove it, just wondering the effect of the glass cleaner. Link to comment Share on other sites More sharing options...
Chris@Adams Posted February 12, 2012 Share Posted February 12, 2012 That is a good question, I would say maybe eventually. I think it would take a bunch of times of glass cleaning. Maybe Dylan will chime in with his opinion. Link to comment Share on other sites More sharing options...
ChargerMatt Posted February 12, 2012 Share Posted February 12, 2012 I use the glass cleaner regularly and I still see the evidence of glass sealant when my windows are fogged up in the right lighting. I would say eventually, just like you will eventually polish through your clear coat. Eventually. Link to comment Share on other sites More sharing options...
07 z-oh-6 Posted February 12, 2012 Author Share Posted February 12, 2012 I figured eventually. I was more curious about right away, like stripping an LSP. Link to comment Share on other sites More sharing options...
07RS4 Posted February 12, 2012 Share Posted February 12, 2012 Ohhh, good question Mark. Dylan will respond with verses from Chemistry textbooks:lol: and more eliquent answers for you I'm sure...but. I'm going to go out and on a limb and say it would take alot of Glass Cleaner to remove the sealant. I have used the Glass Sealant on my windows, and the Glass cleaner really has no affect on the Glass Sealant like Matt said. I'm sure it reduces the life but not by much. That being said, how much more or less durable is the Quick Sealant than the Glass Sealant, I haven't seen a test yet. But if my memory serves me correctly, the Glass Cleaner is really mild stuff, but very affective. I'll let the man give us a clear, consise answer about the make-up of both products. Link to comment Share on other sites More sharing options...
dipolley Posted February 13, 2012 Share Posted February 13, 2012 I would imagine that APC 50/50 water would be your best bet. If need be spray the APC on a rag then wipe the glass. Link to comment Share on other sites More sharing options...
07 z-oh-6 Posted February 13, 2012 Author Share Posted February 13, 2012 I would imagine that APC 50/50 water would be your best bet. If need be spray the APC on a rag then wipe the glass. I don't want to remove it! Link to comment Share on other sites More sharing options...
dipolley Posted February 13, 2012 Share Posted February 13, 2012 I don't want to remove it! Ohhhhhhh, OK. I get it now. I use Brilliant Glaze on my glass personally. Link to comment Share on other sites More sharing options...
3PedalMINI Posted February 13, 2012 Share Posted February 13, 2012 IT DOES NOT WORK! at all. When i did the mini it was all over, i tried glass cleaner and that didnt work. I also tried a bit of alchohol and it worked but I ran out. So i tried stoners invisi-glass and it worked like a champ! (still had near a full can, then i tried adams so it became a paperweight! good for removing the sealant off the windows though! Link to comment Share on other sites More sharing options...
07 z-oh-6 Posted February 13, 2012 Author Share Posted February 13, 2012 IT DOES NOT WORK! at all. When i did the mini it was all over, i tried glass cleaner and that didnt work. I also tried a bit of alchohol and it worked but I ran out. So i tried stoners invisi-glass and it worked like a champ! (still had near a full can, then i tried adams so it became a paperweight! good for removing the sealant off the windows though! Just to clarify, Adam's Glass Cleaner will not remove Quick Sealant from windows, but Stoners Invisible glass will? Link to comment Share on other sites More sharing options...
Z71_Denali Posted February 13, 2012 Share Posted February 13, 2012 are you wondering, because you got some overspray of QS on the glass? if thats the case just keep a single soft in your pocket and when your putting the QS down, if you get some on the glass, just wipe it off immediately before it cures. no reason to actually use it on the glass, thats what Glass Sealant is for! Link to comment Share on other sites More sharing options...
3PedalMINI Posted February 13, 2012 Share Posted February 13, 2012 Just to clarify, Adam's Glass Cleaner will not remove Quick Sealant from windows, but Stoners Invisible glass will? Yup, takes it right off Link to comment Share on other sites More sharing options...
Team Adam's Posted February 13, 2012 Share Posted February 13, 2012 That would be the alcohol content most likely stripping the sealant, no alcohol in our juice! As to the original question... degrade some? Yes. Remove completely in one use? I doubt it. Haven't done any testing, but based on the makeup of the chemicals I'd say you're good to use glass cleaner a few times, then refresh your sealant coating. Link to comment Share on other sites More sharing options...
07 z-oh-6 Posted February 13, 2012 Author Share Posted February 13, 2012 That would be the alcohol content most likely stripping the sealant, no alcohol in our juice! As to the original question... degrade some? Yes. Remove completely in one use? I doubt it. Haven't done any testing, but based on the makeup of the chemicals I'd say you're good to use glass cleaner a few times, then refresh your sealant coating. Perfect answer, thanks. Link to comment Share on other sites More sharing options...
Chewy Posted February 13, 2012 Share Posted February 13, 2012 I just ordered three cans of this to stock up for the spring... I am AMAZED how this stuff is lasting on my wife's Enclave which sits outside 24/7 right now. This stuff will get used more than anything for my vehicles. Chris Link to comment Share on other sites More sharing options...
07 z-oh-6
14 answers to this question
