hemi1300 Posted October 11, 2012 Share Posted October 11, 2012 obviously the blue waffle weave towels for waterless wash, but what towels do u guys use for detail spray? Single soft for application and final wipe of the ds? Just curious what towels work best for application of ds and final wipe after Link to comment Share on other sites More sharing options...
0 Redbeard Posted October 11, 2012 Share Posted October 11, 2012 Your choice, single or double soft microfiber towels. Link to comment Share on other sites More sharing options...
0 Green Machine Posted October 11, 2012 Share Posted October 11, 2012 You can use any of Adams towels!!!!! But I use single soft or blue waffle! Link to comment Share on other sites More sharing options...
0 camaro2ssblack Posted October 11, 2012 Share Posted October 11, 2012 Definitely waterless wash towels, thats the only towel that doesnt lint when wiping wet product in my experience. I will then mist a single soft towel and go over the car one last time for streaks, etc. Link to comment Share on other sites More sharing options...
0 hemi1300 Posted October 11, 2012 Author Share Posted October 11, 2012 thanks for the quick responses, will stick to the ww or single soft, and decide which i like better. Another question about drying-after the pooling rinse and bulk of water blown off with master. Apply detail spray and wipe down with gwdt, do u guys follow up with another towel to eliminate any streaks after the gwdt? Just received my second gwdt, so maybe after the first wipe with ds/gwdt-immediately follow with the next gwdt to soak up any moisture/streaks? Link to comment Share on other sites More sharing options...
0 Chuckkilo3 Posted October 11, 2012 Share Posted October 11, 2012 I use the blue waffle weave towels with detail spray. Works well. Link to comment Share on other sites More sharing options...
0 Redbeard Posted October 11, 2012 Share Posted October 11, 2012 thanks for the quick responses, will stick to the ww or single soft, and decide which i like better. Another question about drying-after the pooling rinse and bulk of water blown off with master. Apply detail spray and wipe down with gwdt, do u guys follow up with another towel to eliminate any streaks after the gwdt? Just received my second gwdt, so maybe after the first wipe with ds/gwdt-immediately follow with the next gwdt to soak up any moisture/streaks? If I have any streaks after drying, I go back over it with a single soft and detail spray as necessary. Link to comment Share on other sites More sharing options...
0 camaro2ssblack Posted October 11, 2012 Share Posted October 11, 2012 the best drying routine I have found is a sheet rinse after washing > pull into the garage and mist the entire car with detail spray > very gently dry most of the water with your GWDT > then break out the master blaster and dry the rest of the paint and hard to reach areas > then hit the door jambs, trunk, engine bay etc with your second GWDT and detail spray > then dry wheels and tires with master blaster - done. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted October 12, 2012 Share Posted October 12, 2012 Here lately I have been using the blue WW towels with DS. Link to comment Share on other sites More sharing options...
0 Feets31 Posted October 12, 2012 Share Posted October 12, 2012 the best drying routine I have found is a sheet rinse after washing > pull into the garage and mist the entire car with detail spray > very gently dry most of the water with your GWDT > then break out the master blaster and dry the rest of the paint and hard to reach areas > then hit the door jambs, trunk, engine bay etc with your second GWDT and detail spray > then dry wheels and tires with master blaster - done. This^^^^^ Link to comment Share on other sites More sharing options...
0 Kingsford Posted October 12, 2012 Share Posted October 12, 2012 Single Soft. Link to comment Share on other sites More sharing options...
0 Chuckkilo3 Posted October 12, 2012 Share Posted October 12, 2012 This^^^^^ I rarely mist with detail spray since I have a Master Blaster. I just wipe the water droplets away with a waffle weave as I go around the vehicle. Much less wiping involved that way. I do the sheet rinsing after blasting the soap from crevices with a water stream. Link to comment Share on other sites More sharing options...
0 rshadd Posted October 12, 2012 Share Posted October 12, 2012 single soft or blue waffle, both work well. Link to comment Share on other sites More sharing options...
0 scociny Posted October 12, 2012 Share Posted October 12, 2012 I have never thought of using the blue waffle...I have always used a single soft, which seems to work well. I will have to give the blue waffles a try. Link to comment Share on other sites More sharing options...
0 AmyAtAdamsAustralia Posted October 12, 2012 Share Posted October 12, 2012 Single soft is great but I personally prefer the double soft for the feel. Both work wonders. Link to comment Share on other sites More sharing options...
0 BRZN Posted October 12, 2012 Share Posted October 12, 2012 Here lately I have been using the blue WW towels with DS. What Chris said. Link to comment Share on other sites More sharing options...
0 blick05SS Posted October 12, 2012 Share Posted October 12, 2012 I havent tried the waffle towel but i may have to. I typically use the single or double softs Link to comment Share on other sites More sharing options...
0 Team Adam's Posted October 12, 2012 Share Posted October 12, 2012 I use doubles and singles for DS, waffle weave for WW. Link to comment Share on other sites More sharing options...
0 Chuckkilo3 Posted October 12, 2012 Share Posted October 12, 2012 I use doubles and singles for DS, waffle weave for WW. You probably have a thousand towels in each category. Link to comment Share on other sites More sharing options...
0 omegaman1978 Posted October 15, 2012 Share Posted October 15, 2012 Single Softs. More tactile feed back. Link to comment Share on other sites More sharing options...
0 koebot Posted October 15, 2012 Share Posted October 15, 2012 WW. No linting and no streaking. I leave the plush towels for polishes and waxes. Link to comment Share on other sites More sharing options...
0 eric@thompsonracing.us Posted October 17, 2012 Share Posted October 17, 2012 I use Single Soft Towels with Detail Spray and save my Double Softs for removing wax/sealant. Link to comment Share on other sites More sharing options...
0 ArmyAcadia09 Posted October 18, 2012 Share Posted October 18, 2012 You probably have a thousand towels in each category. And if he needs more he's got the warehouse downstairs Link to comment Share on other sites More sharing options...
0 DaveVY Posted October 18, 2012 Share Posted October 18, 2012 Most of my use of detail spray is while drying the car so my usual towel with detail,spray is the great white. If I am not using it as a drying agent I will usually use the single soft. Link to comment Share on other sites More sharing options...
0 Chuckkilo3 Posted October 18, 2012 Share Posted October 18, 2012 And if he needs more he's got the warehouse downstairs True dat. Link to comment Share on other sites More sharing options...
0 JBlack151 Posted October 18, 2012 Share Posted October 18, 2012 When I use Detail Spray for a wipe down towards the end of a wash or what have you, I use singles or doubles. The majority of my Detail Spray usage comes from claying. So for that I use Waterless Wash towels. Link to comment Share on other sites More sharing options...
hemi1300
26 answers to this question
