bosco1 Posted June 3, 2015 Share Posted June 3, 2015 is there an Adams product to correct hazing of Headlights/Taillights. I have a P/C with most of the pads that I may need...tks in advance... dan Link to comment Share on other sites More sharing options...
0 The Guz Posted June 3, 2015 Share Posted June 3, 2015 If it's not bad then the machine polishes will work. Then seal them with something like quick sealant. If they are on the rougher side of things they may need some sanding followed by polishing. Give the polishes a shot first. bosco1 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 3, 2015 Share Posted June 3, 2015 Bingo!^^ Link to comment Share on other sites More sharing options...
0 kfxjc Posted June 3, 2015 Share Posted June 3, 2015 I have a set of $800 VW accessory tail lights on my R32. When the paint shop repainted my hatch they hit the tail light with the buffer and marred it pretty good. Anyway to get that out of the plastic? I will get a picture to show it, im sure it will help diag. MattieDSC 1 Link to comment Share on other sites More sharing options...
0 mc2hill Posted June 3, 2015 Share Posted June 3, 2015 I usually start with the MF or a very aggressive foam pad on the drill. That way I can skip sanding most times. You have to be careful with the drill though, as the you essentially are using a rotary polisher. Keep it moving, and don't let the pad dry out. bosco1 1 Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 3, 2015 Share Posted June 3, 2015 As these guys have pointed out - many times just the same process you'd use to correct paint is all thats needed. I always make a point to polish out tail lights and headlights when I'm on the paint correction stages of a detail. If they're really bad you may want to sand first, then work up to polishing, but again it all depends on the condition they started in. bosco1 1 Link to comment Share on other sites More sharing options...
0 ledger64 Posted June 3, 2015 Share Posted June 3, 2015 Just did one of my cars this weekend trying to use up the old 3 step products I have kickin around. I clayed them then polished then sealed with liquid paint sealant. such an improvement bosco1 1 Link to comment Share on other sites More sharing options...
0 avvblanc01 Posted June 3, 2015 Share Posted June 3, 2015 Just did this on the 2006 dodge ram recently bought. Mine were bad enough that they needed to be wet sanded first. I wet sanded with 3,000 grit sand paper, then did the two step correction that I would normally do on paint. After that, I topped the headlights with two coats of sealant. It won't be a permanent fix, but they will stay clear for a few months. bosco1 1 Link to comment Share on other sites More sharing options...
0 CMDChase Posted June 4, 2015 Share Posted June 4, 2015 I still keep a bottle of the old Severe Swirl Remover around for headlights. It works very well. Ask around if anyone has a bottle they'd part with. Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 5, 2015 Author Share Posted June 5, 2015 I still keep a bottle of the old Severe Swirl Remover around for headlights. It works very well. Ask around if anyone has a bottle they'd part with. I have a bottle, tks my friend..btw Picked up a 2000 C5 corvette from a gentlemen in Allentown,Pa a few years ago... Link to comment Share on other sites More sharing options...
0 CntryClub007 Posted June 9, 2015 Share Posted June 9, 2015 I did 4" pad on drill, I think Adam posted a headlight video, I followed that guide... bosco1 1 Link to comment Share on other sites More sharing options...
bosco1
dan
10 answers to this question
