sahls01gmc Posted September 1, 2016 Share Posted September 1, 2016 My truck is covered in bugs right now. When I get home, can I spray diluted Rinseless on the truck and let it sit overnight before I wash it tomorrow morning? Or maybe APC? Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted September 1, 2016 Share Posted September 1, 2016 I would think it would just dry back up overnight. I use rinseless and let it soak for 3-5 mins prior to wipe down and it gets the majority off very easily. If they are super bad I will use all purpose and rinseless combo and of course reapply my lsp Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted September 1, 2016 Share Posted September 1, 2016 I definitely would not recommend letting Rinseless or diluted Rinseless sit on any vehicle surfaces overnight, as that is not how the product is intended to be used. I have never attempted this...but Rinseless Wash can slightly stain my fingers and towels while using it, so I wouldn't want to let it dry onto the vehicle surface. It could also streak and require more sprays to remove, and in the small chance that it did stain the surface, we would not be liable for that if the product is used in this way other than it is intended. As Daniel mentioned above, using it as a pre-soak for a few minutes to help loosen and soften up dead bug guts is fine, but do not let it sit overnight. Rich 1 Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted September 1, 2016 Author Share Posted September 1, 2016 Thanks guys! I was looking for the maximum level of presoak, but don't want to create more work than necessary. Looking to do a quick wash and shine on the work truck. Ya know, some "wash and wax" would really be handy right about now...... Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted September 1, 2016 Share Posted September 1, 2016 If you're talking about diluted solution you could spray some on and it can dry. There are no chemicals in the polymers that would etch in your paint. It will have streaks from drying though, so be sure to "reactivate" with more diluted cleaner and clean appropriately with a traditional wash or a rinseless wash media (mf towel). All purpose cleaner I would not want drying on the paint however. If you are loosening bugs and letting it dry you are defeating the purpose. If anything spray them down and keep them wet for 5-10 mins max and should come off easy. This is why I keep towels and rinseless solution mixed - you have the ability to clean the front end of the bugs in 10 mins and can complete the whole car at your convenience. Link to comment Share on other sites More sharing options...
0 jakerodz7 Posted September 1, 2016 Share Posted September 1, 2016 I have actually tried somewhat of a variation of the options mentioned above, a bit more time consuming but it worked better to remove the bugs so I consider it to be worth the extra time. I went around the whole car, starting in the worse areas and sprayed very liberally with rinseless. Then when I was done going around the whole car (took about 7 minutes) I went back around and re-soaked the whole car. This seemed to work very well as I had no issues removing the bug guts after with the towels soaked in solution. Maybe try that and see if it helps. Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted September 1, 2016 Author Share Posted September 1, 2016 I knew it would dry overnight, but wasn't sure if I was doing any good "reactivating" when I went to wash this morning. I ended up doing a 10 minute soak with Rinseless and APC. Strip Wash would have been amazing for this process. Unfortunately, I got called out just as I got done washing, so the whole truck is naked right now. Hopefully I'll have some time tonight to give it another once over and H2O G&G. Thanks for everyone's input. This is just my work truck, a 2014 Ram 3500. Has 125,000 miles right now. Obviously it gets used a lot, so an efficient system to maximize results and minimize time is ideal. My other vehicles get pampered, but I still can't drive a dirty work truck either. Everytime I'm out of town, I always pack a small detail bag to give me something to do in the hotel at night. Link to comment Share on other sites More sharing options...
0 hemi1300 Posted September 1, 2016 Share Posted September 1, 2016 Good lord that truck gets some use, 125k miles and it's 2 years old! Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted September 2, 2016 Author Share Posted September 2, 2016 Yup. Built in April of 2014. And didn't pick it up til the end of July. I haul Generators all over the 10 states in our territory. Not too many 2 year old vehicles are on their 4th set of tires! Link to comment Share on other sites More sharing options...
sahls01gmc
8 answers to this question
