DIZZYDEVIL Posted January 15, 2017 Share Posted January 15, 2017 I used the deep wheel cleaner today on my zl1, and the rotors seemed to be stained but not the rims. Please help!! Link to comment Share on other sites More sharing options...
0 TheWolf Posted January 15, 2017 Share Posted January 15, 2017 Were the rotors hot, had the car just been driven? Did the product dry on the rotors before being rinsed? Post some photos of the issue. Link to comment Share on other sites More sharing options...
0 DIZZYDEVIL Posted January 15, 2017 Author Share Posted January 15, 2017 Were the rotors hot, had the car just been driven? Did the product dry on the rotors before being rinsed? Post some photos of the issue. They weren't hot I only backed out the garage. It wasn't dry on the rims but it might have dried on the rotors. Even the one I was working on immediately it stained it Link to comment Share on other sites More sharing options...
0 TheWolf Posted January 15, 2017 Share Posted January 15, 2017 It looks like the product dried on the rotors. Have you driven the car to see if the brake pads wear off any of the staining? Norton 1 Link to comment Share on other sites More sharing options...
0 DIZZYDEVIL Posted January 15, 2017 Author Share Posted January 15, 2017 No, but that was next on my list of things to try. 8675309'SS 1 Link to comment Share on other sites More sharing options...
0 2quikta Posted January 15, 2017 Share Posted January 15, 2017 Normal and fine. The rotors will clean themselves with use. The only way to retain clean rotors while washing wheels is to take the wheel off to clean. Norton and DIZZYDEVIL 2 Link to comment Share on other sites More sharing options...
0 SYMAWD Posted January 15, 2017 Share Posted January 15, 2017 They should look fine again after a few stops. zapdon and DIZZYDEVIL 2 Link to comment Share on other sites More sharing options...
0 DIZZYDEVIL Posted January 15, 2017 Author Share Posted January 15, 2017 Thanks guys. I'll check back later after I've driven the car for a few hours. TheWolf 1 Link to comment Share on other sites More sharing options...
0 8675309'SS Posted January 15, 2017 Share Posted January 15, 2017 As the others said drive it and it should be fine. Kinda of alarmed me at first. DIZZYDEVIL 1 Link to comment Share on other sites More sharing options...
0 Rich Posted January 15, 2017 Share Posted January 15, 2017 My rotors actually turn to what looks like rust after I clean them. I just back up and go forward a few times in the driveway and it's all good. Norton and PlainOleS5 2 Link to comment Share on other sites More sharing options...
0 LFairbanks Posted January 16, 2017 Share Posted January 16, 2017 I'm sure driving it around the block and that will be gone. DIZZYDEVIL 1 Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted January 16, 2017 Share Posted January 16, 2017 Nothing different than sitting in the rain a few days and having spots, as soon as you take a nice drive they will be back to normal DIZZYDEVIL and Norton 2 Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted January 16, 2017 Share Posted January 16, 2017 On a related note... I do not use Wheel Cleaner when the Corvette wheels are on the car. Reason being, it has carbon ceramic brakes and they are known to stain. Instead, I use 16:1 diluted Car Shampoo when the wheels are on the car. (The wheels are protected with Quick Sealant and CCBs dust less than some other brakes.) Link to comment Share on other sites More sharing options...
0 stingrayc7 Posted January 16, 2017 Share Posted January 16, 2017 Just drive your car and it's gone.. Any wheel cleaner or car soap will do the same to the rotors.. It's totally fine. Norton 1 Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted January 16, 2017 Share Posted January 16, 2017 I'm not so sure about that Mohammad. CCBs are different than ceramic brake pads...the CCB rotors are a carbon ceramic material, not iron. Considering the replacement cost of CCB rotors, I'm keeping Wheel Cleaner away from them. Link to comment Share on other sites More sharing options...
0 SumBeach35 Posted January 16, 2017 Share Posted January 16, 2017 (edited) Wheel cleaner is some strong stuff. It damaged the factory coating on my GF's 2017 Ford Explorer front brake calipers. Did it on first wash, was used at full strength at the recommended dwell time. It may have still been a bit warm from a trip earlier in the day. It sucks it happened but I'm sure I'll eventually paint them when the new wheel and tire package gets picked out. Everything will be coated at the same time. Edited January 20, 2017 by SumBeach35 Link to comment Share on other sites More sharing options...
0 dskinsler83 Posted January 17, 2017 Share Posted January 17, 2017 why is there so much panic when people clean the wheels and this happens to rotors? This is normal oxidation in a rapid form from the aggressive cleaning solvent. it is surface level only, move the car 20ft and use the brakes and boom it is gone. As far as CBC rotors, I dunno but it is still a solid surface but posing the question to adams tech support would be best for those. Norton and PHOKUS 2 Link to comment Share on other sites More sharing options...
0 DIZZYDEVIL Posted January 19, 2017 Author Share Posted January 19, 2017 I didn't drive until today, but rotors are looking good ???????????????? Link to comment Share on other sites More sharing options...
0 texinfin Posted January 19, 2017 Share Posted January 19, 2017 why is there so much panic when people clean the wheels and this happens to rotors? If it happens to your 2004 Toyota Camry that is fine. When it happens to a Camaro ZL1 that costs 60k panic mode ensues until you find out everything is ok. DIZZYDEVIL, falcaineer, 8675309'SS and 1 other 4 Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted January 20, 2017 Share Posted January 20, 2017 If it happens to your 2004 Toyota Camry that is fine. When it happens to a Camaro ZL1 that costs 60k panic mode ensues until you find out everything is ok. Oh, to be young again... LFairbanks 1 Link to comment Share on other sites More sharing options...
0 falcaineer Posted January 21, 2017 Share Posted January 21, 2017 Oh, to be young again... Yes, but the panic Kapri felt probably aged him 10 years anyway! Link to comment Share on other sites More sharing options...
0 dskinsler83 Posted January 23, 2017 Share Posted January 23, 2017 Oh, to be young again... I'm not far from it only 33 which is young to me. It is just more of a realistic knowledge of chemical processes that are thought in middle and high school levels in my opinion Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted January 23, 2017 Share Posted January 23, 2017 Ha, I'm only 31. I was just messin' with ya. If I saw that stain on any other surface, I'd be worried. But my rotors turn colors overnight just from sitting. They shine right up first time I hit the brakes! Link to comment Share on other sites More sharing options...
0 DIZZYDEVIL Posted January 24, 2017 Author Share Posted January 24, 2017 I'm not far from it only 33 which is young to me. It is just more of a realistic knowledge of chemical processes that are thought in middle and high school levels in my opinion *Taught * not thought Opinion noted, but I didn't ask for it. The question was for solution also it never stained before so I asked a question. neontrucks 1 Link to comment Share on other sites More sharing options...
0 dskinsler83 Posted January 24, 2017 Share Posted January 24, 2017 Ha, I'm only 31. I was just messin' with ya. If I saw that stain on any other surface, I'd be worried. But my rotors turn colors overnight just from sitting. They shine right up first time I hit the brakes! Oh I wasn't replying in an ill manner. And yeah depending on the weather etc I can have rusted looking rotors overnight. Shoot look at them on cars at the dealership. They can do they same as well. Link to comment Share on other sites More sharing options...
0 dskinsler83 Posted January 24, 2017 Share Posted January 24, 2017 *Taught * not thought Opinion noted, but I didn't ask for it. The question was for solution also it never stained before so I asked a question. You are correct it would be taught not thought. Thank you ???? Link to comment Share on other sites More sharing options...
DIZZYDEVIL
26 answers to this question
