When I got home I noticed the below on my paint. It's absolutely stuck on there even with my cquartz coating (sorry adam's product wasnt available at the time I got my car ). I tried the following: soap & water, general wipe, some tar cleaner, goo gone, and clay. I did however manage to use the blue heavy correcting polish on a pad and about 80% came off with no apparent damage to the paint or clear. I used it by hand just incase there were some adverse effects.
Should I go ahead and throw it on my orbital? The paint surface less than the stupid contamination has been cleaned to best I can. Or should I try something chemically aggressive like the wheel cleaner and treat the spot? It has completely ran down the entire side of my rear quarter panel.
It's not really rough to the touch and it's very smooth but it simply will not come off. It's all over my rear glass however, I'm able to scrape it off. Ideally I dont want to take a razor blade to the glass but it'll come off. I have some 3000 grit auto sandpaper but I'd like to avoid wet sanding it. :(
initial e
Guys/gals,
14 answers to this question
