I know we talk a lot about paint correction and things of that nature. What isn't discussed as frequently is how to know when you're safe to correct and when you're not, or how aggressive you can be in doing so. For those purposes, a paint thickness gauge is invaluable. There's a number of gauges out there that range in price from a little over $100 to thousands of dollars. The one we use is a mid level gauge. Before we take a polisher to any vehicle, we want to determine how aggressive we can be and if it will stand up to polishing.
The way we commonly do this is to measure the paint in multiple areas. We then measure an area that won't have as thick of a clear coat on it (door jambs are a good one) and subtract it to get a feel for roughly what thickness of clear coat we are working with. We can also discover quickly if a vehicle has had any paint work done on it. Body shops will commonly lay down a much thicker clear coat than the factory.
Here you can see a paint reading of 100 microns on an Infiniti G35 we recently did some work on. This is a pretty common reading among paint that hasn't been touched.
In taking more readings, we came across a few panels that had much thicker readings.
This let us identity that those panels had been repainted. While working with this vehicle, we found an isolated deep scratch that we wanted to pull out.
We took a quick reading and found the paint was VERY thick in this area thanks to the repaint.
Yup, 297 microns. That's some thick paint to work with. We went to work with some compound (that wasn't Adam's as we wanted a super quick cut and had something more aggressive on the shelf). We followed it up with some correcting polish and finally a finishing polish.
In that photo, there was plenty more to be done on the vehicle, we were just working that one isolated spot. A quick final reading shows we actually removed a significant amount of clear coat to remove the defect.
Through the use of a paint thickness gauge, we were able to determine how aggressive we could (or couldn't be) and could work confidently while choosing a product that would offer fast results. Every vehicle has a story to tell. And before we write our chapter on it with polishes, correction and general awesomeness in detailing we should take a moment to understand what's really going on. On a vehicle with a much thinner coat of clear, I don't know as though we would have been quite so aggressive.
Paint thickness gauges are an invaluable tool for anyone who's doing paint correction on a regular basis or where you're working on vehicles you don't really know the history of.
Just thought I'd share an experience with an area of detailing that is often not talked about much here.
shane@detailedreflections
Enjoy and have a great weekend.
11 answers to this question
