Did the Vette today, and with two very thin coats it wipes off super easy with the white towel. Gives a darker / deeper finish, very nice. I let the finish cure for a few hours then misted with DS / MF towel as a final step.
Two points though:
1. When first running the spong pad over the wax in the container I got little hard shavings of wax, seemed the top surface was very dry. It took about 3 or 4 swipes to get down to a smooth moist surface in the container. I wonder if a spritz with DS in the container might be a good idea for the first use.
2. With my container the entire wax slab spins in the container, so you can't twist the spong pad to get wax on the spong. Either my container is odd, or maybe the bottom of the container could have a serated base to hold the wax slab from spinning.
Just a suggestion, but overall a terrific product.
DCRANER
Two points though:
33 answers to this question
