So in my last order of refills on products and new wash pads, I also picked up a Metro Blaster Sidekick to help with the drying process.
Good grief, it's a vacuum cleaner in reverse! As more or less expected, it is somewhat loud, though not unbearably so. But it does pump out a solid, forceful stream of tangibly warmed air that, in a few seconds, will dry off water on trim and tires. For that it works very well.
Of course, if your car decides it wants to keep leeching water out of every orifice as my G8 does, blowing water out of the cracks doesn't help much. So my hope of eliminating all the water dripping out from the lip spoiler and side mirrors didn't quite pan out. Still, there's many cases in which it did help. For instance, I used it to blow water out from around the lug nuts on my tires and then dry them off so I could put VRT on right away.
Great little product, really. Doesn't get everything out of the cracks, but it does help. Only two tips I'd have that I'll follow myself for next time.
Blow water out of the cracks before toweling off the rest of the car. The Blaster evacuated quite a bit of water from some cracks, such as around my side mirrors. The result was that I had to re-dry some panels I'd already previously toweled.
Wear ear protection! It's not that the device itself is so loud, but the sound the blast of air makes on some trim and tire lugs was piercing.
Eidolon
Thanks, Adam!
Edited by EidolonLink to comment
30 answers to this question
