jub jub Posted November 23, 2008 Share Posted November 23, 2008 I'm trying to remove scratches from my paint and I'm making a mess. This is the result after using the orange pad and swirl and haze remover with my orbital. What am I doing wrong or is this the way it should look? Link to comment Share on other sites More sharing options...
0 jub jub Posted December 3, 2008 Author Share Posted December 3, 2008 Hey Jub :hi:Where are those pics? Oh yea. Tonight! Link to comment Share on other sites More sharing options...
0 Ashley@Adams Posted December 3, 2008 Share Posted December 3, 2008 I'm trying to remove scratches from my paint and I'm making a mess. This is the result after using the orange pad and swirl and haze remover with my orbital. What am I doing wrong or is this the way it should look? Hi John, Thank you for joining us!! My recommendation is to start with the orange pad and use a equally small amount of Fine Machine Polish and Swirl and Haze Remover (I use about 4 pea size squirts of each). Only do about a fender sized area at a time. The technique is crucial in this situation. After you spread the product evenly, you want to turn the speed up to about 5,500 OPM's. At about two inches per second, move the PC vertically and then horizontally. I'm not a fan of a circular motion. You want to do straight lines up and down. Repeat, Repeat, Repeat until the polish breaks down. Then after that, take the white pad with some FMP and give it a quick one over. This process is a little time consuming but you will save your paint and as long as the car is kept in good shape, you won't have to repeat the process. Besides, it's therapeutic to polish. I hope this helps and if you have more questions, please let me know. My direct number is below. I also have a sheet typed up with VERY specific instructions. I will be more than happy to email it to anyone who needs it! Link to comment Share on other sites More sharing options...
0 jub jub Posted December 3, 2008 Author Share Posted December 3, 2008 This should be a liitle better. I still want to polish a little more with the fine stuff and then wax. Link to comment Share on other sites More sharing options...
0 Ashley@Adams Posted December 3, 2008 Share Posted December 3, 2008 this should be a liitle better. I still want to polish a little more with the fine stuff and then wax. wonderful! Link to comment Share on other sites More sharing options...
0 jub jub Posted December 3, 2008 Author Share Posted December 3, 2008 Hi John, Thank you for joining us!! My recommendation is to start with the orange pad and use a equally small amount of Fine Machine Polish and Swirl and Haze Remover (I use about 4 pea size squirts of each). Only do about a fender sized area at a time. The technique is crucial in this situation. After you spread the product evenly, you want to turn the speed up to about 5,500 OPM's. At about two inches per second, move the PC vertically and then horizontally. I'm not a fan of a circular motion. You want to do straight lines up and down. Repeat, Repeat, Repeat until the polish breaks down. Then after that, take the white pad with some FMP and give it a quick one over. This process is a little time consuming but you will save your paint and as long as the car is kept in good shape, you won't have to repeat the process. Besides, it's therapeutic to polish. I hope this helps and if you have more questions, please let me know. My direct number is below. I also have a sheet typed up with VERY specific instructions. I will be more than happy to email it to anyone who needs it! Thanks Ashley for the help. I think I have a good grasp of the technique, I just need to work it a little more for that perfect mirror finish. Link to comment Share on other sites More sharing options...
0 Ashley@Adams Posted December 3, 2008 Share Posted December 3, 2008 Thanks Ashley for the help. I think I have a good grasp of the technique, I just need to work it a little more for that perfect mirror finish. Awesome! If you learn anything cool while you're detailing. Let us know! Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted December 4, 2008 Share Posted December 4, 2008 Great Job Link to comment Share on other sites More sharing options...
0 jjwvette Posted December 4, 2008 Share Posted December 4, 2008 This should be a liitle better. I still want to polish a little more with the fine stuff and then wax. Much better Jub Link to comment Share on other sites More sharing options...
0 Adam Posted December 4, 2008 Share Posted December 4, 2008 (edited) I'm trying to remove scratches from my paint and I'm making a mess. This is the result after using the orange pad and swirl and haze remover with my orbital. What am I doing wrong or is this the way it should look? Hi John- This is an easy one! Not enough pressure was used when using the Orange Swirl Killer pad, and the speed setting was too low. Please try this: Start with the Swirl & Haze Remover, and a mist of Detail Spray. Start at setting 5, apply 30+ lbs of pressure, and go SLOW. Move your PC to setting 6, and continue over the area. Leave the residue on, and then give the pad a spritz of Detail Spray and apply some Fine Machine Polish, still going very SLOW. Now, switch to the White Pad, remain at setting 6, and use the Fine Machine Polish again. Remove the Residue, and WALLA!!! You should be looking flawless. Will you please post after photos after you do this? Thanks! Adam:thumbsup: Edited December 4, 2008 by Adam Link to comment Share on other sites More sharing options...
0 jub jub Posted December 11, 2008 Author Share Posted December 11, 2008 Hi John- This is an easy one! Not enough pressure was used when using the Orange Swirl Killer pad, and the speed setting was too low. Please try this: Start with the Swirl & Haze Remover, and a mist of Detail Spray. Start at setting 5, apply 30+ lbs of pressure, and go SLOW. Move your PC to setting 6, and continue over the area. Leave the residue on, and then give the pad a spritz of Detail Spray and apply some Fine Machine Polish, still going very SLOW. Now, switch to the White Pad, remain at setting 6, and use the Fine Machine Polish again. Remove the Residue, and WALLA!!! You should be looking flawless. Will you please post after photos after you do this? Thanks! Adam:thumbsup: I posted some pics up above. It looks better for sure but I'm still not happy with it. If you get real close and at the right angle you can still see tiny scratches. I would like to see a mirror finish if I can. I'll try the white pad and Fine Machine Polish again. Question: How often do you wash the pads? I've been washing them after every use put a friend told me there is no need as long as you don't cross contaminate with different products. Link to comment Share on other sites More sharing options...
0 Adam Posted December 17, 2008 Share Posted December 17, 2008 (edited) Hi John, man, I'm not happy that you are not mirror yet! Let's try this: White Pad (clean is good) 5K OPM's (setting 5) 50% Swirl & Haze, 50% Fine Machine Polish. Light mist of Detail Spray on the pad Go VERY slow, and just concentrate on 12" square of the worst scratches. Bump the machine to 6K OPM's Apply some Fine Machine Polish, go over at 5K Remove residue with Super Plush Towel Look good? Go to the SuperWax. Still more to go? Try this: Swirl & Haze, 6K OPM's, white pad (no need to clean the pad) Fine Machine, 6K, White, then remove residue. Report back with results John, and keep my cell handy to ring me before, during, or after you try this method: 303-718-9480. Thanks! Edited December 17, 2008 by Adam Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted December 17, 2008 Share Posted December 17, 2008 :help:Hi Adam , How many times could you go through these steps before you might damage the clearcoat on a new car ? Chris Link to comment Share on other sites More sharing options...
0 Rich Posted December 17, 2008 Share Posted December 17, 2008 I'm still not sure I'd put a machine to my black. Maybe at Carlisle, someone can convince me. I'm so picky, I wouldn't be able to live with swirls like that. Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted December 17, 2008 Share Posted December 17, 2008 I'm still not sure I'd put a machine to my black. Maybe at Carlisle, someone can convince me. I'm so picky, I wouldn't be able to live with swirls like that. You keep that car looking like that by hand !!!!!!!! You must have better rotorcuffs than me Link to comment Share on other sites More sharing options...
0 Adam Posted December 18, 2008 Share Posted December 18, 2008 :help:Hi Adam , How many times could you go through these steps before you might damage the clearcoat on a new car ? Chris Hi Chris, using the orbital, you would have to polish non-stop, 24 hours/ day, for a few weeks before you would start thinning out your clear coat. That's the good news, and bad! Bad? Well, correcting serious surface imperfections will require sand paper and /or a rotary buffer. Using a D/A Polisher doesn't build up heat, and cut the finish very fast. Hence, going over again to correct it is sometimes needed. Using a high speed buffer will do the trick in half the time, but it's very easy to damage and/or burn the clear with one. Hope this explains it. The Dual Action Polisher just doesn't do the cutting, so the damage potential is EXTREMELY low. Link to comment Share on other sites More sharing options...
0 jub jub Posted December 18, 2008 Author Share Posted December 18, 2008 Hi John, man, I'm not happy that you are not mirror yet! Let's try this: White Pad (clean is good) 5K OPM's (setting 5) 50% Swirl & Haze, 50% Fine Machine Polish. Light mist of Detail Spray on the pad Go VERY slow, and just concentrate on 12" square of the worst scratches. Bump the machine to 6K OPM's Apply some Fine Machine Polish, go over at 5K Remove residue with Super Plush Towel Look good? Go to the SuperWax. Still more to go? Try this: Swirl & Haze, 6K OPM's, white pad (no need to clean the pad) Fine Machine, 6K, White, then remove residue. Report back with results John, and keep my cell handy to ring me before, during, or after you try this method: 303-718-9480. Thanks! Thanks Adam! You da man when it comes to customer service! Link to comment Share on other sites More sharing options...
0 jjwvette Posted December 18, 2008 Share Posted December 18, 2008 I'm still not sure I'd put a machine to my black. Maybe at Carlisle, someone can convince me. I'm so picky, I wouldn't be able to live with swirls like that. No need to be afraid:glasses: Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted December 18, 2008 Share Posted December 18, 2008 Adam , Thanks ! Chris Link to comment Share on other sites More sharing options...
0 Adam Posted December 20, 2008 Share Posted December 20, 2008 Adam , Thanks ! Chris Thank you Chris! Link to comment Share on other sites More sharing options...
0 Adam Posted December 20, 2008 Share Posted December 20, 2008 No need to be afraid:glasses: Looking good Jim!!! Link to comment Share on other sites More sharing options...
0 Bluezey Posted December 20, 2008 Share Posted December 20, 2008 (edited) Edited December 30, 2008 by Bluezey Link to comment Share on other sites More sharing options...
0 estecoca Posted December 30, 2008 Share Posted December 30, 2008 omg...that 'vette is SICK. Makes me want to throw my PC away and leave it to the pros. Amazing shine! Link to comment Share on other sites More sharing options...
0 bigred vette Posted December 30, 2008 Share Posted December 30, 2008 omg...that 'vette is SICK. Makes me want to throw my PC away and leave it to the pros. Amazing shine! save it! you dont need the pros to get shine like that, check out the back of my vette. and trust me im no pro... Link to comment Share on other sites More sharing options...
0 XCELR8S Posted December 30, 2008 Share Posted December 30, 2008 I am frustrated... I purchased the Gen 2 system and finally had a good day to work on my Vette... I tried everything that was recommended in this posting to get the marks out of my black paint and it actually looks worse . After battling this problem for over a year, my hats off to those who can get this to work . I have tried using the orange pad with swirl and haze remover and worked to the white pad. I tried just the white pad and the polishes. I tried less polish and higher OPMs as well. I worked very slow with pressure until polish broke down and no success. Open to suggestions at this point. Link to comment Share on other sites More sharing options...
0 Nitelord Posted December 30, 2008 Share Posted December 30, 2008 save it! you dont need the pros to get shine like that, check out the back of my vette. and trust me im no pro... She's a beauty Brian. No doubt... Link to comment Share on other sites More sharing options...
jub jub
Top Posters For This Question
15
12
11
10
Popular Days
Nov 23
16
Dec 30
12
Nov 27
9
Dec 31
8
jub jub 15 posts
Adam 12 posts
Bill-V8V 11 posts
XCELR8S 10 posts
Popular Days
Nov 23 2008
Dec 30 2008
Nov 27 2008
Dec 31 2008
83 answers to this question
