Cleaning Fabric Wheel Well Liners
Go to solution Solved by Ricky Bobby,
In my previous(2011 Silverado) "weekly wash" routine I would clean the plastic wheel well lines with APC and the Adam's fender brush.  I got a 2015 Silverado and that comes with front and back wheel well liners that look to be a heavy felt type product rather than plastic.  Is it safe to use my previous routine(APC w/brush) or will the fender brush tear or soften up the liners?  Thanks
Link to post
14 answers to this question
The 'carpet' liners are for sound deadening to reduce road noise, but they are a major pain in the rear to clean.
Mostly I just go crazy with the pressure washer and try to use that to get everything out, scrubbing usually isn't effective. It doesn't hurt the 'carpet' but the brush sticks and is hard to work with.
APC can be used to break things up, but you will get a lot of foaming in there and have to spend a lot of time rinsing it out.
Link to post
Thanks for all the replys.  I was mainly concerned with the brush "breaking apart" or "tearing into" the liners.  We have a lot of salt still on the roads here, so I am going to try some diluted APC on those areas as they seem to be already showing some signs of staining.
Link to post
Because not only do they reduce noise, vibration & harshness they also reduce weight.
And they use recycled materials to make them.
Thankfully this is here already because it was going to be one of my questions.
Edited by CadillaChick
Link to post
I went at these yesterday and got some pretty good results.  The only thing I might change is on the final step after they are dried I should go back over them with an old upholstry brush or roller to remove the lint.   It did take about double the time it usually did on the plastic liners.
1. Brush off all 4 liners with dry fender brush
2. Hose out with stream from firehose nozzle until water ran clear
3. Hit salt sports with diluted APC and agitate with wet fender brush
4. Rise until water runs clear.
5. Used master blaster to try after I finished the rest of the vehicle
I hopes this helps anyone else that was/is in the same boat.
Link to post
On 11/18/2020 at 8:04 PM, TonyG said:
Has anyone tried spraying them with an undercoating?
4 hours ago, 07stanggt said:
Welcome to the forum. But, probably not a good idea to spray any type of undercoating on that carpet type material.
Fabric Protector might work, but they would need cleaned and dried thoroughly first. Longevity is still a question, too, since the wheel wells take quite a beating.
Link to post
Answer this question...
