Olgrey93 Posted July 31, 2017 Share Posted July 31, 2017 Hi folks,hope all is well I just purchased a small bissel portable carpet cleaner. I was curious which would be better to pre scrub the carpets with? Diluted apc (old version) or carpet and upholstery cleaner full strength Link to comment Share on other sites More sharing options...
0 Rich Posted July 31, 2017 Share Posted July 31, 2017 Follow the directions for the Bissell and use the Carpet and Upholstery Cleaner. I use it on my carpets in the house with great results. ledger64 1 Link to comment Share on other sites More sharing options...
0 Mariner Posted July 31, 2017 Share Posted July 31, 2017 Definitely Carpet and Upholstery cleaner. All I use it for is in the house. It works great for pet stains. Nickfire20 1 Link to comment Share on other sites More sharing options...
0 rkj4243 Posted July 31, 2017 Share Posted July 31, 2017 +3 on the advice above.............. Nickfire20 1 Link to comment Share on other sites More sharing options...
0 Nathan Posted July 31, 2017 Share Posted July 31, 2017 Follow the directions for the Bissell and use the Carpet and Upholstery Cleaner. I use it on my carpets in the house with great results. Definitely Carpet and Upholstery cleaner. All I use it for is in the house. It works great for pet stains. +3 on the advice above.............. I’ve been thinking about getting one as a mini extractor for a while, which one did you guys go with? Link to comment Share on other sites More sharing options...
0 Chonke Posted July 31, 2017 Share Posted July 31, 2017 Ive had 2 different Bissell carpet cleaners. One was a handlheld one which i still have in the garage. Its an older model but still works. Then i bought the proheat pet liftoff upright carpet cleaner. The bottom part would detach to create a portable unit too. We bought the second one because it was supposed to pick up dog hair easier. However, the difference was minimal. Not enough to justify having two, so I returned the big one and kept the old small one. Not long after that, I started using my 16 gallon ridgid shop vac from home depot and havent used the bissell since. The suction is so much more powerful on the shop vac. So what I do know is spray the carpet with adams carpet and upholstery cleaner liberally, and just vacuum everything out. If theres is a lot of hair or stubborn stains, use a small horse brush or adams cockpit brush to agitate it a bit and itll come off. Just another option, but to answer OPs question, yes carpet and upholstery cleaner will be a better choice here. Link to comment Share on other sites More sharing options...
0 rkj4243 Posted July 31, 2017 Share Posted July 31, 2017 I’ve been thinking about getting one as a mini extractor for a while, which one did you guys go with? Bissell Spot Clean Pro............................... was available on Amazon. Fairly priced for the results achieved! Link to comment Share on other sites More sharing options...
0 BRZN Posted July 31, 2017 Share Posted July 31, 2017 APC is a sudsing detergent Carpet & Upholstery Cleaner is non-sudsing and made for cleaning carpets and upholstery Sudsing type detergents will reactivate when wet since it's nearly impossible to remove all of it from the carpet fibers. If it's reactivated by the bottom of your shoes being wet the carpet will be cleaning the bottom of your shoes. Stick with the designated product for the job, you'll have much better results. mc2hill, falcaineer and Nathan 3 Link to comment Share on other sites More sharing options...
Olgrey93
