airhog Posted December 13, 2008 Author Share Posted December 13, 2008 <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p>I need a permanent heater that will maintain the temperature. This Reddy Heater is great to warm it up and keep it warm but if I shut it off then the garage will cool down quickly in cold temperatures. So I need a more consistent temperature.<o:p></o:p> </o:p> Link to comment Share on other sites More sharing options...
Krzdimond Posted December 14, 2008 Share Posted December 14, 2008 <o:p>I need a permanent heater that will maintain the temperature. This Reddy Heater is great to warm it up and keep it warm but if I shut it off then the garage will cool down quickly in cold temperatures. So I need a more consistent temperature.<o:p></o:p></o:p> You could always try this: http://www.warmzone.com/otherproducts.asp and this: http://www.power-blanket.com/site/page Link to comment Share on other sites More sharing options...
airhog Posted December 14, 2008 Author Share Posted December 14, 2008 Thanks Link to comment Share on other sites More sharing options...
airhog Posted December 22, 2008 Author Share Posted December 22, 2008 Anymore helpful heating tips or ideas? Link to comment Share on other sites More sharing options...
Retired_CPO Posted December 23, 2008 Share Posted December 23, 2008 My old house in Maryland was heated with oil fired hot water heat. I just ran another zone of that boiler to the garage. The hot water fed a square radiator that looked like a typical box fan (approximately 26" x 26"). It was hung from the ceiling in one corner and was thermostatically controlled. When heat was needed hot water flowed from the boiler in the house out to the garage and through the radiator and the fan behind it blew warm air diagonally across the three garage bays. It worked great. But now that I am in Florida, heating the garage is not an issue. I cool the garage with a stand alone 2 ton air conditioner and run it only when it is hot and I am going to be working in the garage for longer than 10 minutes. Rich Rich, You wouldn't happen to have any pics of this set up would you? I am very interested in doing something like this to my garage. thanks. Link to comment Share on other sites More sharing options...
Rich427 Posted December 23, 2008 Share Posted December 23, 2008 Rich, You wouldn't happen to have any pics of this set up would you? I am very interested in doing something like this to my garage. thanks. No I don't have any pictures, but I just did a quick search on the web and found something like what I had. I am not recommending this company, they just had some decent pictures of the radiator unit. http://www.greenhousemegastore.com/products.asp?dept=1056&gclid=CLiZzYjH15cCFRJ4xgodawEdEA Since my house was heated with an oil fired boiler. I just ran another zone from the boiler out to the garage. That zone also had its own thermostat in the garage. We just ran some all thread from the fan box up through the garage ceiling and through a cross member mounted to the roof joist. The hot water ran into the radiator and through the coils and the fan on the back would turn on and blow hot air across the garage. Then the water would return to the boiler. I placed the unit in the right front corner of the garage (near the house) and pointed it towards the the left most corner by the garage door. It worked great! If I knew I was going out to work in the garage, about 20 minutes before I went out there I would turn the thermostat up to about 65 degrees. I could work all day out there in just shirt sleeves. I hope this helps! Rich Link to comment Share on other sites More sharing options...
jim293 Posted December 25, 2008 Share Posted December 25, 2008 I just use a propane heater works really well. Do not really have to use it all that often out here in Calif. Link to comment Share on other sites More sharing options...
airhog Posted December 14, 2009 Author Share Posted December 14, 2009 It has been awhile since the weather has been cold so I decided to bring up the question again. What do you use to heat your garage in the winter? Also if you have any questions or comments please post them Thanks airhog.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p> Link to comment Share on other sites More sharing options...
whiterp199 Posted December 14, 2009 Share Posted December 14, 2009 I use hopes and dreams! Hopefully I will change that soon enough. Link to comment Share on other sites More sharing options...
bigred vette Posted December 14, 2009 Share Posted December 14, 2009 I use hopes and dreams! Hopefully I will change that soon enough. :lol: +1! Link to comment Share on other sites More sharing options...
Bill-V8V Posted December 14, 2009 Share Posted December 14, 2009 It has been awhile since the weather has been cold so I decided to bring up the question again. What do you use to heat your garage in the winter? Also if you have any questions or comments please post themThanks airhog.<o:p></o:p> Yup, and if memory serves me it got cold around this time the year before too Link to comment Share on other sites More sharing options...
70'sChevyGirl Posted December 14, 2009 Share Posted December 14, 2009 As I posted in another thread... From parka to butt naked in 5 minutes! One thing that is true, you must have good vetilation to use something like this, especially if yours uses kerosene. My uses gas or kerosene and my garage is a drafty as Aunt Jemima's bloomers. We use a similar bullet heater. It seems to do the trick and within an hour or so the pole barn is warm enough to paint cars. BTW AJ, how drafty are Aunt Jemina's bloomers?? Link to comment Share on other sites More sharing options...
11chevz71 Posted December 14, 2009 Share Posted December 14, 2009 oil Link to comment Share on other sites More sharing options...
Chris@Adams Posted December 14, 2009 Share Posted December 14, 2009 Real men don't need heat. Rich are you a real man? Link to comment Share on other sites More sharing options...
Junkman2008 Posted December 14, 2009 Share Posted December 14, 2009 ... BTW AJ, how drafty are Aunt Jemina's bloomers?? You could use them for a Powerball drawing. Link to comment Share on other sites More sharing options...
2008fx4 Posted December 14, 2009 Share Posted December 14, 2009 live in southern arizona..... Link to comment Share on other sites More sharing options...
Rich Posted December 15, 2009 Share Posted December 15, 2009 Rich are you a real man? I've been married 36 years, so I guess my answer is "not anymore". Link to comment Share on other sites More sharing options...
Junkman2008 Posted December 15, 2009 Share Posted December 15, 2009 I've been married 36 years, so I guess my answer is "not anymore". Thirty-six years? Good grief, was Moses in your shop class? Link to comment Share on other sites More sharing options...
Chris@Adams Posted December 15, 2009 Share Posted December 15, 2009 I've been married 36 years, so I guess my answer is "not anymore". :lolsmack: Link to comment Share on other sites More sharing options...
Rich Posted December 15, 2009 Share Posted December 15, 2009 Thirty-six years? Good grief, was Moses in your shop class? Nah, he was in yours. ADAM was in mine. Link to comment Share on other sites More sharing options...
Junkman2008 Posted December 15, 2009 Share Posted December 15, 2009 Nah, he was in yours. ADAM was in mine. You callin' me old there geezer? Link to comment Share on other sites More sharing options...
70'sChevyGirl Posted December 15, 2009 Share Posted December 15, 2009 I've been married 36 years, so I guess my answer is "not anymore". :lolsmack: Your wife's job is done. Link to comment Share on other sites More sharing options...
PatsFan Posted December 15, 2009 Share Posted December 15, 2009 First let me apologize in advance for coming across as a hard ***. This subject is near and dear to me. I would never detail my own car because I am clueless but, when it comes to CO poisoning and sick building syndrome I am at the top of my field so please heed my advice. NEVER NEVER NEVER use an unvented fossil burning (Nat. gas,LP,kerosene etc.)heater in any building that is also used for human habitation.Best case scenario, you will be polluting the air and growing massive mold colonies. Worst case scenario, you or someone you love will find themselves very dead !!! Unvented heaters should only be used for temporary heat in extremely well ventilated and UNinsulated situations.If you must use temporary heaters indoors please use electric but, be wary of the fire hazards they impose. Everybody please repeat this one hundred times; NEVER NEVER NEVER use an unvented fossil burning (Nat. gas,LP,kerosene etc.)heater in any building that is also used for human habitation Link to comment Share on other sites More sharing options...
rha600 Posted December 15, 2009 Share Posted December 15, 2009 <---- south florida. If you ant to heat the garage up just open the door. Link to comment Share on other sites More sharing options...
Junkman2008 Posted December 15, 2009 Share Posted December 15, 2009 They stress that fact on the units PatsFan. Some folks don't head it but in my case, I wasn't joking when I said my garage is drafty. Built in 1892, insulation must have been a luxury. The air completely recycles in minutes! Link to comment Share on other sites More sharing options...
