In 2005, I purchased a new Honda S2000 with red paint.
Unfortunately I was ignorant about properly washing, drying, and sealing/waxing, so I introduced the usual imperfections into the paint.
Now that I am familiar with detailing (having adopted the Junkman's regime), I used my 1995 Toyota Tacoma pickup truck to practice with. While I did encounter a number of issues, I was able to achieve satisfactory results. For an 18 year old daily driver truck that had never been detailed nor properly taken care of, I was able to correct the paint as good as I wanted it. (Which is to say it wasn't perfect; however I did not want to "take it to the next level" -- which likely would have involved wet sanding.)
However my S2000 is a different story--I am desirous of restoring the paint to "like new" condition. Yet I am at my wits end because of the following issues:
1) What kind of paint is on a 2005 Honda S2000?
a. It doesn't appear to have a clear coat finish because all the pads (orange; white; black) end up with red paint in them.
b. The paint seems to be very soft--even with a Porter-Cable 7424XP or Griot's Garage Random Orbital set to speed 4, the finish is always marred -- so much so that Adam's Detail Spray won't remove it, nor will 3M Clean and Shine (water + isopropyl alcohol solution), nor will Dawn Ultra dish soap! I tried different speeds but it was always present to some degree.
2) Is it usual for the paint on a 2005 Honda S2000 to have "a lot" of orange peel?
I ask because every photo/video of S2000s having been detail show a perfectly flat finish--no orange peel that I can see.
3) Some panels have turned-out okay (e.g. the trunk) while others are incredibly problematic (e.g, the hood & driver-side panels).
4) Are the plastic bumpers painted with the same paint as the car or are they made of plastic colored the same as the car?
This S2000 was "Made in Japan" -- yet I wonder: did they jack-up the paint on mine?
So here's where I'm at now: after many hours of trying different things such as: changing pads (Hex-Logic orange; white; black; and Adam's 6" white), using different machines (PC; Griot's 6" and 3"); different products (Meguiar's 105 and 205; 3M Ultrafina SE (swirl eliminator)), I've thrown my hands up in surrender and am ready to take it to a professional detailer unless this forum can help me!
Some surface "marring" left-over after polishing (visible to right of the spotlight)
Two new Adam's 6" white pads after a couple of passes each with Meguiar's 205. N.B.: red clumps of polish/paint residue on paper after just two passes on speed 4! Temperature/humidity was about 60F/20% in the garage.
Orange peel on passenger side:
Close-up of orange peel and a new Adam's 6" white pad after two passes with Meguiar's 205:
Nevada Smith
![IMG_7196.JPG](http://iptechnica.com/images/IMG_7196.JPG)
Edited by Nevada SmithLink to comment
25 answers to this question
