This morning I finally had a chance to use my new Cyclo for the first time for some paint correction and then applying a coat of Liquid Paint Sealant to my daily driver. As a total noob to machine polishing, I must say the Cyclo used with Adam's paint correction polishes and pads was super easy and worked awesomely!
My question is this: How much pressure, if any, should be used when applying Liquid Paint Sealant with the gray Sealant and Wax pads? The reason I ask is because when I was all finished and went to clean my pads, there was a ton of LPS that had absorbed into the pads, and it took me a long time with several rounds of Dawn dish soap and All Purpose Cleaner to get it all out. (Actually, I don't know if I did get it all out, I kind of gave up after a while- being waterproof, LPS is hard to wash out!) When applying, I was just using the weight of the machine to spread out the sealant, but if so much got absorbed into the pads, should I have used more pressure to "squeeze" it out of the pad? Or, is that just the way it goes?
gbod
6 answers to this question
