Jayco76 Posted February 26, 2015 Share Posted February 26, 2015 Which product would you use as the 2nd to last step in a weekly wash regimen ? Detail spray or brilliant Glaze? (with the last step being standing back and admiring the work you just finished ) Lately I have been using brilliant Glaze because the chrome accents are typically the last part I clean Link to comment Share on other sites More sharing options...
0 ForceofWill Posted February 26, 2015 Share Posted February 26, 2015 DS to finish the weekly wash, I don't use BG on a weekly basis only during wax time and maybe before a show. DS is nice to finish with and get out any streaks or water marks from the wash for sure. Link to comment Share on other sites More sharing options...
0 mc2hill Posted February 26, 2015 Share Posted February 26, 2015 Personally it would be DS. I usually only use BG for show prep. But nothing wrong with what you are doing. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted February 26, 2015 Share Posted February 26, 2015 Use both.......DS at every wash as a drying agent and every 3 or 4 washes you can apply a coat if BG, after DS wipe down. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted February 26, 2015 Share Posted February 26, 2015 Either or both. Weekly Glaze might be a bit overkill, but wouldn't be the end of the world either. Personally I'm more of a DS every wash guy then BG every couple of washes if its being used in my process. Ricky Bobby 1 Link to comment Share on other sites More sharing options...
0 Black Bowtie Posted February 26, 2015 Share Posted February 26, 2015 Not worried about it now because of winter, but does Brillant Glaze attract dust like Detail Spray? I have a black truck so it shows dust bad. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted February 26, 2015 Share Posted February 26, 2015 Nothing we sell 'attracts' dust... detail spray or brilliant glaze... it doesn't do anything to repel it either though. If you are experiencing a high amount of dust on a vehicle it has more to do with a static charge on the paint from rubbing it than it does the chemicals you're using. You can fix this by grounding the vehicle - using a copper wire and a couple of metal clips (like a jumper cable) clip to your frame or a pinch weld on the lower rockers, attach the other end to a piece of rebar staked into the ground. That grounds the vehicle, releases the charge and reduces the dust accumulation by a good amount. I have a piece of rebar tied into the foundation of my garage that I clip the C-10 to to keep the dust down. Makes a huge difference. NowDatsG, BluedogGMC, PT3 and 3 others 6 Link to comment Share on other sites More sharing options...
0 Junior Posted February 26, 2015 Share Posted February 26, 2015 I use Detail Spray to dry after a bucket wash. Even use sometimes post rinseless wash. Love BG but use it less frequently. Like most, I throw BG in with application of Wax etc. Pretty sure BG wont build up like wax so it is something that can be used as much as you want. I have used Glaze on the windows lately. Need to see how that works now my Glass cleaning is on another level:) Link to comment Share on other sites More sharing options...
0 Junior Posted February 26, 2015 Share Posted February 26, 2015 Nothing we sell 'attracts' dust... detail spray or brilliant glaze... it doesn't do anything to repel it either though. If you are experiencing a high amount of dust on a vehicle it has more to do with a static charge on the paint from rubbing it than it does the chemicals you're using. You can fix this by grounding the vehicle - using a copper wire and a couple of metal clips (like a jumper cable) clip to your frame or a pinch weld on the lower rockers, attach the other end to a piece of rebar staked into the ground. That grounds the vehicle, releases the charge and reduces the dust accumulation by a good amount. I have a piece of rebar tied into the foundation of my garage that I clip the C-10 to to keep the dust down. Makes a huge difference. Son you got some knowledge Link to comment Share on other sites More sharing options...
0 PT3 Posted February 28, 2015 Share Posted February 28, 2015 Nothing we sell 'attracts' dust... detail spray or brilliant glaze... it doesn't do anything to repel it either though. If you are experiencing a high amount of dust on a vehicle it has more to do with a static charge on the paint from rubbing it than it does the chemicals you're using. You can fix this by grounding the vehicle - using a copper wire and a couple of metal clips (like a jumper cable) clip to your frame or a pinch weld on the lower rockers, attach the other end to a piece of rebar staked into the ground. That grounds the vehicle, releases the charge and reduces the dust accumulation by a good amount. I have a piece of rebar tied into the foundation of my garage that I clip the C-10 to to keep the dust down. Makes a huge difference. NOW I understand why everyone on the board was so stoked to have you back. You're a pro and it shows. Glad to have you as a SME (Subject Matter Expert) here in the community. Link to comment Share on other sites More sharing options...
0 BluedogGMC Posted February 28, 2015 Share Posted February 28, 2015 Nothing we sell 'attracts' dust... detail spray or brilliant glaze... it doesn't do anything to repel it either though. If you are experiencing a high amount of dust on a vehicle it has more to do with a static charge on the paint from rubbing it than it does the chemicals you're using. You can fix this by grounding the vehicle - using a copper wire and a couple of metal clips (like a jumper cable) clip to your frame or a pinch weld on the lower rockers, attach the other end to a piece of rebar staked into the ground. That grounds the vehicle, releases the charge and reduces the dust accumulation by a good amount. I have a piece of rebar tied into the foundation of my garage that I clip the C-10 to to keep the dust down. Makes a huge difference. I know years ago they used to hang a rubber strip from somewhere under the car or truck that just touched the ground to eliminate static. Do they still do this? Link to comment Share on other sites More sharing options...
0 TheWolf Posted February 28, 2015 Share Posted February 28, 2015 I know years ago they used to hang a rubber strip from somewhere under the car or truck that just touched the ground to eliminate static. Do they still do this? Funny, I was just looking at those grounding straps on Amazon. Most had poor reviews. I did order a few parts to make a grounding clip to use when it is parked. Will be interesting to see how this reduces the dust. Link to comment Share on other sites More sharing options...
0 Beemer Posted February 28, 2015 Share Posted February 28, 2015 I have some old jumper cables that I just connected to the Rocket and the grounded metal frame of my garage. The dust level is pretty low in there right now but we'll see.... Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted March 1, 2015 Share Posted March 1, 2015 Same idea as natural gas line service trucks that hang ground straps, some propane and railroad trucks as well. Link to comment Share on other sites More sharing options...
0 Sean Ryan Posted September 19, 2015 Share Posted September 19, 2015 Which product would you use as the 2nd to last step in a weekly wash regimen ? Detail spray or brilliant Glaze? (with the last step being standing back and admiring the work you just finished ) Lately I have been using brilliant Glaze because the chrome accents are typically the last part I clean I use Detail Spray as a drying aid and Brilliant Glaze as a last step after every wash to make my black paint pop i love Brilliant Glaze Link to comment Share on other sites More sharing options...
0 Black Bowtie Posted September 21, 2015 Share Posted September 21, 2015 (edited) I have been using diluted Rinseless Wash as a drying aid for over 6 months replacing my Detail Spray when it ran out. With the wax in Riseless, it really leaves a great shine on my black truck on the paint, chrome, wheels and glass. It would be hard for me to go back to Detail Spray and one less product I have to keep on hand. Have also been using it on my plastic parts in the interior and looks great. Edited September 21, 2015 by Black Bowtie Link to comment Share on other sites More sharing options...
0 Texas Moe Posted September 21, 2015 Share Posted September 21, 2015 I have been using diluted Rinseless Wash as a drying aid for over 6 months replacing my Detail Spray when it ran out. With the wax in Riseless, it really leaves a great shine on my black truck on the paint, chrome, wheels and glass. It would be hard for me to go back to Detail Spray and one less product I have to keep on hand. Have also been using it on my plastic parts in the interior and looks great. Rich, I'm going to try your method with the RW. Did you mix it at the 16:1 ratio? Link to comment Share on other sites More sharing options...
Jayco76
16 answers to this question
