sahls01gmc Posted March 23, 2016 Share Posted March 23, 2016 What do you guys use to remove heavy grease? All Purpose Cleaner will only work so well, and a pressure washer would do some damage under the hood. Any chemical that will help lift the grease off? Link to comment Share on other sites More sharing options...
0 chops1sc Posted March 23, 2016 Share Posted March 23, 2016 I've seen people use a product called Rapid Remover on heavy grease. I haven't used it myself though. I just spray with a higher concentrated degreaser and let it sit for a little bit then hit it again and agitate. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted March 24, 2016 Share Posted March 24, 2016 How heavy is the grease. You'd need a solvent based remover, I'd use something like Tarminator to break it up if it's too much for apc. Link to comment Share on other sites More sharing options...
0 chops1sc Posted March 24, 2016 Share Posted March 24, 2016 I just remembered I have used non chlorinated brake cleaner to get caked on grease from my old trucks engine. Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted March 24, 2016 Share Posted March 24, 2016 I just remembered I have used non chlorinated brake cleaner to get caked on grease from my old trucks engine. Brake cleaner does work well on grease but is very hard on rubber and plastics. BrianT 1 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted March 24, 2016 Share Posted March 24, 2016 I have used APC, does a decent job, if you need a bit more my go to is Simple Green for things. Its a lot more environmentally friendly to the world and you. Make it up nice and strong, wet down the engine area, spray on, let it sit for a bit quick scrub and you should be ok. Link to comment Share on other sites More sharing options...
0 chops1sc Posted March 24, 2016 Share Posted March 24, 2016 Brake cleaner does work well on grease but is very hard on rubber and plastics.I agree, I only use it on the engine parts. The little hose on the end lets you spray it directly where you want it. blcksilv08 1 Link to comment Share on other sites More sharing options...
0 BRZN Posted March 24, 2016 Share Posted March 24, 2016 Use a foaming aerosol cleaner specifically made to clean engines and follow the instructions on the can. These can be found at any auto parts store, or automotive section of most any box store. As long as the vehicle isn't from the 80's, you can use the pressure washer under the hood (which will make the job much easier). Use common sense, use the General Purpose, or delicate nozzle and don't directly spray the hood liner, the alternator, the opening to the air box, or electrical connectors. Ricky Bobby and LT1xL82 2 Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted March 24, 2016 Share Posted March 24, 2016 I agree, I only use it on the engine parts. The little hose on the end lets you spray it directly where you want it.Bingo At work on nasty engines, suspensions and fifth wheels we use a commercially available degreaser that is similar to simple green just a bit more aggressive. After letting that soak for a few minutes, just like Dave said use a pressure washer with some common sense. Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted March 24, 2016 Author Share Posted March 24, 2016 Thanks for the replies! How similar is All Purpose Cleaner to Simple Green? And how different are they? I think my method will be a heavy engine de-greaser foe the bad spots, then APC for a final, once over on the engine bay. Link to comment Share on other sites More sharing options...
0 Zach5.9CTD Posted March 26, 2016 Share Posted March 26, 2016 Purple power at full strength. Agitate if needed. Link to comment Share on other sites More sharing options...
sahls01gmc
10 answers to this question
