I finally used up my 16oz car shampoo so I installed the pump in my gallon replacement, and put it to use. I really love the simplicity and speed of the pump, for filling my foam cannon as well as the bucket.
However, as I tidied up after a carwash I noticed that there was shampoo running down the gallon container, which had clearly dripped from the output end of the pump. I pulled up on the neck of the pump and found it was still compressed a little, so maybe that caused some of the leaking? This morning when I left my garage, I saw that there was more that had dripped though not as much as initially. Bummer.
Am I doing anything wrong, should I check the assembly of the pump, could there be pressure built up inside the gallon container?
butters
13 answers to this question
