avimore Posted August 5, 2016 Share Posted August 5, 2016 Hi, new to detailing and wanted to know what the best applicator is to apply LPS by hand? I have seen a video where Adam applies LPS with the Red Hex Grip Applicator but I have also seen the Blue Microfiber Applicator being used. Is one easier to use than the other? Pros and Cons? It appears that the Red Hex applicator would be easier to clean/maintain, but I am new to all this so looking for some guidance. Thanks. Link to comment Share on other sites More sharing options...
0 chops1sc Posted August 5, 2016 Share Posted August 5, 2016 (edited) I have used the MF Applicator and it works great for getting into tight areas. I know you mentioned applying by hand, but I use my polisher and a black/gray pad and get the best results. Edited August 5, 2016 by chops1sc LT1xL82 and PHOKUS 2 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted August 5, 2016 Share Posted August 5, 2016 The microfiber applicators work fine but its easier to lay it down thin with a hex grip IMO - I've used both and prefer hex grip applicators for applying sealant - you also use less product Green Machine 1 Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted August 5, 2016 Share Posted August 5, 2016 Machine application makes for a thin even coat of LPS. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 6, 2016 Share Posted August 6, 2016 By hand I like applying PS with a MF pad. Green Machine 1 Link to comment Share on other sites More sharing options...
0 Mariner Posted August 6, 2016 Share Posted August 6, 2016 I like applying with the microfiber pad as well because it leaves nice rectangular coverage, and it's easier to get into corners. Link to comment Share on other sites More sharing options...
0 avimore Posted August 7, 2016 Author Share Posted August 7, 2016 Thanks guys, great info. Link to comment Share on other sites More sharing options...
0 PHOKUS Posted August 7, 2016 Share Posted August 7, 2016 Hex applicator or machine-applied. The MF applicator soaks up too much product IMO stripesace 1 Link to comment Share on other sites More sharing options...
0 mhsmith0109 Posted January 1, 2017 Share Posted January 1, 2017 Do you have to use the red hex applicator or can you use the blue or yellow one? I did buy the microfiber pad but think a hex applicator might be easier. Link to comment Share on other sites More sharing options...
0 falcaineer Posted January 1, 2017 Share Posted January 1, 2017 (edited) Do you have to use the red hex applicator or can you use the blue or yellow one? I did buy the microfiber pad but think a hex applicator might be easier. The PS isn't meant to remove any blemishes or swirls, so you'll want to use a soft applicator like the red or yellow, or the grey pad on a machine. The blue will probably be a little too "harsh," for lack of a better term. Edited January 1, 2017 by falcaineer Norton 1 Link to comment Share on other sites More sharing options...
0 Norton Posted January 1, 2017 Share Posted January 1, 2017 (edited) The PS isn't meant to remove any blemishes or swirls, so you'll want to use a soft applicator like the red or yellow, or the grey pad on a machine. The blue will probably be a little too "harsh," for lack of a better term. +1. Stick with appropriate applicator/chemical combos... Red, Yellow, or Grey for PS and Wax. Orange, Blue, or White for Compound and Polishes. Edited January 1, 2017 by Norton falcaineer 1 Link to comment Share on other sites More sharing options...
0 neontrucks Posted January 1, 2017 Share Posted January 1, 2017 +1. Stick with appropriate applicator/chemical combos... Red, Yellow, or Grey for PS and Wax. Orange, Blue, or White for Compound and Polishes. Great to know, I never paid attention the hex applicators had diffrent grades of foam. Sure glad I've been using as directed???? Link to comment Share on other sites More sharing options...
0 stripesace Posted January 1, 2017 Share Posted January 1, 2017 Red Hex Grip. Microfiber pad I found to be too aggressive for applying it. I use a red hex grip applicator to get everywhere the Rupes 15 MkII won't get and then do the rest with the Rupes on a speed of 1-2 and a black pad. Keep the machine moving for a nice thin coat.Let it sit for an hour or so, sometimes overnight, and then buff off so easily with a grey plush borderless. The stuff wipes leaving you an amazing depth of color and incredible shine. Link to comment Share on other sites More sharing options...
0 Rb1274 Posted January 1, 2017 Share Posted January 1, 2017 Just did my truck and used the microfiber pad. Was a bit hard to hold on to... LPS is strong stuff Link to comment Share on other sites More sharing options...
avimore
Thanks.
13 answers to this question
