Twalsh1103 Posted December 8, 2017 Share Posted December 8, 2017 Hey everyone, I am brand new to this forum and not very experienced with forums in general. Also, I am in major need of a 15 mm Adam's swirl killer because I currently have a Rupes 21 mm ES and although it is great, the throw is obviously so big, I could use a smaller throw to get other areas of my car when the 21 gets inconvenient. I mean I do have a Harbor freight but 1. I think it's an 8 mm and 2. It's the biggest piece of trash I have ever seen. Using proven 3M compound, Hex Logic Medium-Heavy foam cutting pad, and god knows how many passes with ample pressure....this thing could not take out 30% of the scratches & swirls. I like the idea of a 15 because it can slot right in between the 21 mm Rupes & the 8 mm Piece of garbage I may find random uses for. I'll probably pick up the swirl killer mini eventually to get those pillars and stuff more easily, and then I can gladly drop my harbor freight out of a 25 story window into a fire pit . Please let me know if you would like to get rid of yours at a decent price!!! (15 mm or swirl killer mini) Or if anyone you know may be looking to get rid of theirs! Just letting you know before pitching me an offer, I can get a brand new 15 mm swirl killer for $171.75 and a swirl killer mini for $112.50 through a detailing connect I have. So if your going to throw me an offer it obviously has to be less than either one of those prices!!! ocdrifter 1 Link to comment Share on other sites More sharing options...
shane@detailedreflections Posted December 8, 2017 Share Posted December 8, 2017 Sounds like you already found a great deal. I’m not sure why you haven’t jumped on it? Get both and be done with it. The mini has a ton of uses and is a great addition. Nickfire20 and ocdrifter 2 Link to comment Share on other sites More sharing options...
falcaineer Posted December 8, 2017 Share Posted December 8, 2017 First, welcome! Second, I agree with both Joe and Shane above...go with the known knowns and just buy those. Doubt you'll find someone on here willing to part with either for such a deal unless they are trying to get out of the Adam's addiction! Nickfire20 and Twalsh1103 1 1 Link to comment Share on other sites More sharing options...
mc2hill Posted December 8, 2017 Share Posted December 8, 2017 What size backing plate are you using on the HF polisher? I have a PC, and found it works best with a 5" backing plat and thinner pads. That being said, the long throw polishers are a huge improvement, and the 15 is the sweet spot. You could put a 3" backing plate on the HF and use it for tight areas. Twalsh1103 1 Link to comment Share on other sites More sharing options...
BG SQ5 Posted December 9, 2017 Share Posted December 9, 2017 Sounds like you're a week late. Could have scored one plus $100+ worth of product for $200. 3" backing plate on the HF is a decent idea. That's what I'm doing with my PC. Nickfire20 1 Link to comment Share on other sites More sharing options...
Twalsh1103 Posted December 9, 2017 Author Share Posted December 9, 2017 10 hours ago, mc2hill said: What size backing plate are you using on the HF polisher? I have a PC, and found it works best with a 5" backing plat and thinner pads. That being said, the long throw polishers are a huge improvement, and the 15 is the sweet spot. You could put a 3" backing plate on the HF and use it for tight areas. Thank you for the information, I actually was not aware of that. I could definitely try that out. I generally just don't like the machine though because how much it vibrates and how loud it is. But before completely knocking it, I suppose that can be an option. Link to comment Share on other sites More sharing options...
Twalsh1103 Posted December 9, 2017 Author Share Posted December 9, 2017 13 hours ago, shane@detailedreflections said: Sounds like you already found a great deal. I’m not sure why you haven’t jumped on it? Get both and be done with it. The mini has a ton of uses and is a great addition. Only reasons i haven't jumped on it are because since I have those 2 others I figured perhaps there's a way to make them work a bit better since I am only decently experienced with polishing. I noticed there are many life hacks to things, and detailing is a place where life hacks are everywhere. For example, I was a bit bummed when I had gotten the Rupes ES because the mark 2 came out soon after. But then I learned from a friend that you can take out the heat shield and put a spacer in and it will prevent the machine from bogging down by alot, which helps make up for part of the fact that the mark 2's motor has 30% more power. But, I am absolutely addicted to detailing and have grown to love adams so I will likely buy the 15 mm mystery bucket if it appears again next year. Link to comment Share on other sites More sharing options...
ocdrifter Posted December 9, 2017 Share Posted December 9, 2017 On 12/8/2017 at 8:51 AM, falcaineer said: First, welcome! Second, I agree with both Joe and Shane above...go with the known knowns and just buy those. Doubt you'll find someone on here willing to part with either for such a deal unless they are trying to get out of the Adam's addiction! I don’t know how this happens, but my posts keep getting deleted some how, did I say something horrible to offended someone again? Or is someone F'ing with me? I don’t see my post here is it deleted or some thing? Please let me know? falcaineer 1 Link to comment Share on other sites More sharing options...
ZMAN024 Posted December 9, 2017 Share Posted December 9, 2017 5 hours ago, ocdrifter said: I don’t know how this happens, but my posts keep getting deleted some how, did I say something horrible to offended someone again? Or is someone F'ing with me? I don’t see my post here is it deleted or some thing? Please let me know? I know your post was there for a while. I read it and also believe I posted a "like" reaction. Link to comment Share on other sites More sharing options...
Rich Posted December 9, 2017 Share Posted December 9, 2017 8 hours ago, ocdrifter said: I don’t know how this happens, but my posts keep getting deleted some how, did I say something horrible to offended someone again? Or is someone F'ing with me? I don’t see my post here is it deleted or some thing? Please let me know? I can't imagine why. As for your comment, it was a bit too rude and the mods felt it wasn't necessary. But me, I'm just messing with ya. In good fun, so don't take it wrong. Twalsh.............welcome to the forum! Link to comment Share on other sites More sharing options...
ocdrifter Posted December 9, 2017 Share Posted December 9, 2017 4 hours ago, ZMAN024 said: I know your post was there for a while. I read it and also believe I posted a "like" reaction. Im just wondering who rude I was lol, most people think I’m really bad but others think I’m a saint ?, I know for all my bad deeds I try to do minimal two good ones. ZMAN024, Rich and Nickfire20 1 2 Link to comment Share on other sites More sharing options...
