Bill68vett Posted May 16, 2021 Share Posted May 16, 2021 Anyone else having issue with the nozzles not spraying after a couple of uses? I have 2 bottles of each and they died after the first use. Purchased 3 more sprayers and they are now all dead as well.... Link to comment Share on other sites More sharing options...
0 RayS Posted May 16, 2021 Share Posted May 16, 2021 I've had my share of problems with the baby sprayers also. If you take your finger nail or something similar and scrape the front where the spray comes out prior to trying to pull the trigger you can usually unplug it. I also have a needle that I can insert into the end if the the first method fails. Be aware that the needle can make the hole a bit bigger so can become more of a spray than a mist. Alternately you can go by one of the hobby stores and pick up a couple of paint sprayers. If it is compatible with acrylic, then it will generally work well with other sealant type products. Nickfire20 1 Link to comment Share on other sites More sharing options...
0 Beemer Posted May 16, 2021 Share Posted May 16, 2021 Yep. I've had trouble with those little sprayers as well. Link to comment Share on other sites More sharing options...
0 Bill68vett Posted May 16, 2021 Author Share Posted May 16, 2021 Thanks good to know I am not the only one let’s hope Adam’s does something to fix this issue Link to comment Share on other sites More sharing options...
0 Rich Posted May 16, 2021 Share Posted May 16, 2021 Been having a lot of issues with these not spraying. Link to comment Share on other sites More sharing options...
Bill68vett
4 answers to this question
