Effectively Cleaning and Drying the Gen2 Pads
GerryC
(I apologize in advance for the range of the quality of the photos. In the ones where I needed both my hands on the products, I had to rely on my camera's self-timer to take the shot while being suspended from my neck on the strap, and resting against my stomach to keep it steady. Like the Junkman's productions, this came raw from my basement, and the pads weren't even used - I just took some product and rubbed it on for the purpose of this topic) :D
One of the most-asked questions about the Gen2 polishing pads is how to effectively clean, and, especially, dry them. I've taken the time to explain my technique below, along with some photos to help with the explanations.
Ok, so you just finished eliminating your swirl marks, polishing the finish to a perfect gloss, and finally laid a coat of superwax to protect all your hard work. You think you're done, but not exactly. You've got to clean out the pads you just used
You'll want to clean these out fairly soon, for a number of reasons. If you let the polish residue dry on (and in) the pad, it will be much more difficult to remove later, and you could rip the pad trying to remove dried up bits left on the surface. Also, you could cause damage to your paint the next time you try to use the pad if it has not been cleaned of dried up polish.
So how do you effectively clean the Gen2 pads? Grab yourself some Adam's All Purpose Cleaner (or Green Wheel Cleaner if you don't have any APC) and spray down the pads liberally, focusing on areas that have a lot of polish.
After spraying them down, gently agitate the pads with your thumbs to work the cleaner into the pad and break loose the polish. The more dense pads (white, and especially orange) will need more effort than the black pad.
Now, thoroughly rinse the pads out with a pressurized stream of water. If you're doing this outside, your hose nozzle will work fine. If you're inside like I am, use the sprayer attachment on your sink. Hold the pad perpendicular to the ground and spray at a 45-degree angle starting at the top of the pad working down, using a side-to-side sweeping motion. This technique forces the cleaner and polish residue down the pad and out the bottom. I do it this way for the same reason that you would wash a car from the top down.
If there is still polish left on the pad after rinsing, simply repeat the cleaner, agitation, and rinsing steps again.
Now it's time to dry the pads, which is a concern I have seen often lately on the forum. If simply left to air-dry, these pads, especially the more dense white and orange ones, would take forever. If not dried completely (as with anything absorbent) they can become moldy (depending on their storage conditions), or if the pads are put in a sealed bag or container while still damp, condensation will form inside it.
The first step to drying the Gen2 pads is to squeeze out as much water as you can by hand, being careful not to break the black plastic ring around the velcro.
The next step involves using your wash bucket and Porter-Cable. We are going to use Newton's First Law (UGH, PHYSICS?!?!?) to get most of the remaining water out of the pads. Set the PC to about speed 2-3. For each pad, put it back on the PC, and position it inside the wash bucket with the pad parallel to the ground, as depicted below:
There is still water standing inside the pads, and it will stay there unless acted upon by an external force. Turn on your PC to introduce said force, and let it run for no longer than 5 seconds. Letting the machine free-spin for any length of time is not good for either the PC or the pads. You can hold the pad with your free hand if you want more control. Make sure you are doing this with the pad inside the bucket. The majority of the water left in the pad will sling out, hit the sides of the bucket, and fall to the bottom.
After doing all of the pads, they will still be slightly damp. You can let them air dry now that you've removed 90% of the moisture. You can also put them in your dryer if it has a stationary rack on the lowest heat setting possible for a few minutes. Or, what I do is sit the pads next to a dehumidifer if you have one. Blotting the pads with your waffle weave drying towel also helps soak up any water left over.
I know it sounds like a lot to do, but I spend about 10 minutes total cleaning, rinsing, and slinging all 3 pads before sitting them out to dry. Following this procedure will dramatically reduce the time it takes for the pads to dry, which is good especially if you have more than one car to do.
Edited by GerryC
  • Answers 64
  • Created
  • Last Reply
Top Posters For This Question
Hey Nick! I've cleaned applicators in the wash before, and here's the kicker: You will get a little ring of car polish around the inside of your washing machine, and that will require a quick wipe with the Detail Spray and a towel to remove, if you are not caught.
I was caught, and then, I was barred from ever washing my car care goods in our home washing machine ever again. (My wife ruined a favorite skirt after I washed a load of applicators, and that was all it took.)
You see, the applicators are literally filled with polish and wax, and those products are not easily broken down with wash soap. It takes a more concentrated effort to get them clean, as with the polishing pads.
I'd say rinsing out the apps with APC in the sink is a very easy way to clean them, and worthwhile.
Having spent the night on the couch that evening, it was a memorable experience.
Hope this helps!
-Adam:thumbsup:
Hope this helps!
-Adam:thumbsup:
:lolsmack:
Hope this helps!
-Adam:thumbsup:
Thanks for the info/advice Adam. I know about sleeping on the couch. (Been there, done that, have the T-shirt.)
However since I no longer have one of those, a wife that is, she decided she "needed her own space" in 1985.
(That Women's lib thing was in full swing at the time and one of her bra burning girlfriends convinced her she
didn't need a husband anymore.) After 25 years of marriage.
Also being retired, 98% of my wardrobe consists of T-shirts and shorts. So if I ruin and occasional shirt, no big deal.
So I think I'll give it a try and see what happens.
What about spraying the applicators with APC and then tossing them in the washer?
Hope this helps!
-Adam:thumbsup:
:lol::lol:Same here! So now what I have to do is when I wash my micros in the washing machine, I have to wash them FIRST, then I wash my car towels with an extra rinse.
Then she washes the house towels and by that time (hopefully) all of the residue is long gone before she washes clothes.
The next step involves using your wash bucket and Porter-Cable. We are going to use Newton's First Law (UGH, PHYSICS?!?!?) to get most of the remaining water out of the pads. Crank the PC up to 5-6. For each pad, put it back on the PC, and position it inside the wash bucket with the pad parallel to the ground, as depicted below:
There is still water standing inside the pads, and it will stay there unless acted upon by an external force. Turn on your PC to introduce said force, and let it run for no longer than 5 seconds. Letting the machine free-spin for any length of time is not good. You can hold the pad with your free hand if you want more control. Make sure you are doing this with the pad inside the bucket. The majority of the water left in the pad will sling out, hit the sides of the bucket, and fall to the bottom.
This certainly works well but as you said; "Letting the machine free-spin for any length of time is not good."
Another method that works well for me is attaching the pad to rotary buffer and let it spin for 5 to 10 seconds without fear of damaging the machine.
Just thought I'd post what's been working for me.
BobbyG
I always clean my pads after every use. I spray them with APC and wash them in the sink with warm water. To dry you can put them on your PC at a lower speed ,run your PC inside your wash bucket and the water wil sling off.Than set up to finish drying.:2thumbs:
I didn't even think about that. I tried to squeeze as much water out as I could by hand without bending the pad. Took forever to dry! Thanks
:iagree:
Just tried that. Works well! Once I spun each of them in the wash bucket, they dried out in no time, and no laundry to do as with towel blotting. Give me that low maintenance.
Just finished up my first detail on my car! 5 1/2 hrs....my body ahces(hand detail) :help:...lol! I am 80-85% satisfied with my work. Hopefully I will get better as I move forward :D. Now to the question, how do you clean the applicator pads? Just run them under water to get the stuff out. Do you need to wash them out at all? The MF towels, I didn't mark them before I used them (SHR..RP..BW) after they have been cleaned I assume it will be ok to use them without know which one was used for what before? Next time I will mark each one. Thanks to all you guys and gals who have provided great info on learning to do this myself and actually enjoying seeing the final results :2thumbs:
Well, I just looked a little further and found my answer. People are using APC and warm water in the sink. If I don't have any APC but have Simple Green can that be used? Should I just spray the pad down with SG and rinse away?
I just give the applicators a good shot of APC and then rinse them under running water. They have cleaned up great for me.
As for the towels, I clean them like the Junkman suggests in his thread, so long as it cleans up well it goes back on the pile to be used next time. Never really thought about seperating them by use. Clean is clean to my thinking. If I screw up and get grease on them or something, they become engine bay towels. ;)
