chevyguy8893 Posted November 28, 2008 Share Posted November 28, 2008 I have used a california water blade for a little while now on my truck. It works really well for me, but is there any long term damage that could happen as the blade gets older, I wipe the thing off after every swipe. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 28, 2008 Share Posted November 28, 2008 I make it a rule to not bash other products but I will say that I've seen the water blade hit a rough spot in a clear coat, skid across a body panel, and leave 6 hours of scratches to buff out. Link to comment Share on other sites More sharing options...
0 97F1504RAD Posted November 28, 2008 Share Posted November 28, 2008 I have been using them for years with no ill effects. I would keep and eye on the blade and if it looks worn buy a new one. I like the jelly version myself prevents thing like Jason said form happening. I also always hose mine of prior to using and after use. I also like to mist the vehicles with the detail spray prior to wiping makes it glide easier and then when you use the WW for final dry it makes it much nicer looking and helps get rid of any spotting that may occur. Link to comment Share on other sites More sharing options...
0 Marylander Posted November 28, 2008 Share Posted November 28, 2008 I have been using them for years with no ill effects. I would keep and eye on the blade and if it looks worn buy a new one. I like the jelly version myself prevents thing like Jason said form happening. I also always hose mine of prior to using and after use. I also like to mist the vehicles with the detail spray prior to wiping makes it glide easier and then when you use the WW for final dry it makes it much nicer looking and helps get rid of any spotting that may occur. That's pretty much how I use mine. I'm obsessive about making sure the edge is completely clean before I touch it to the car, and I spray a light coat of Detail Spray on the car to glide it along. Rich Link to comment Share on other sites More sharing options...
0 Rich Posted November 28, 2008 Share Posted November 28, 2008 Been using one for years and have no complaints. If you go to car shows, there's usually a guy around that sells a rubber one (usually has a Chevy or Ford, etc. emblem on it). Stay away from those. They don't work. The California blade is the only one I use. Link to comment Share on other sites More sharing options...
0 CRQuarto Posted November 28, 2008 Share Posted November 28, 2008 Been using one for years and have no complaints. If you go to car shows, there's usually a guy around that sells a rubber one (usually has a Chevy or Ford, etc. emblem on it). Stay away from those. They don't work. The California blade is the only one I use. Use the jelly blade one as he said, not the cheap rubber ones. Make sure you do it fast too to keep dirt from settling on the car, and keep everything well lubed with detail spray. All of the tips here are great, and as long as you are careful they can be used without issue. Link to comment Share on other sites More sharing options...
0 chevyguy8893 Posted November 29, 2008 Author Share Posted November 29, 2008 That's good to know since I love using this thing for my truck to cut down drying time. I will just pay attention to it and hopefully i won't scratch anything. I should probably replace it and get one of the jelly handled ones and get rid of my old plastic handled blade. Thanks. Link to comment Share on other sites More sharing options...
0 Rich Posted November 29, 2008 Share Posted November 29, 2008 Use the jelly blade one as he said, not the cheap rubber ones. Make sure you do it fast too to keep dirt from settling on the car, and keep everything well lubed with detail spray. All of the tips here are great, and as long as you are careful they can be used without issue. I don't use mine with detail spray. I just use it to swish the water off the cars after I wash them. Then I towel dry and detail. Link to comment Share on other sites More sharing options...
0 Adam Posted November 29, 2008 Share Posted November 29, 2008 No problems with the Blade, unless rubber edge gets a little chewed up. I've only heard of them causing damage when they are used long after they are ready to be tossed! Link to comment Share on other sites More sharing options...
0 jjwvette Posted November 29, 2008 Share Posted November 29, 2008 I don't use mine anymore:pc:blast it with air Link to comment Share on other sites More sharing options...
0 Bluezey Posted November 29, 2008 Share Posted November 29, 2008 (edited) Edited December 30, 2008 by Bluezey Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted December 6, 2008 Share Posted December 6, 2008 I don't use mine anymore:pc:blast it with air I agree. I have come to the conclusion that anytime you can avoid actually touching the paint with anything, you have just eliminated another opportunity to leave a scratch. Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted December 6, 2008 Share Posted December 6, 2008 I have one and it is gathering dust in a cabinet with the other gadgets I have tried, I don't like to drag anything across my paint besides microfiber Link to comment Share on other sites More sharing options...
0 jub jub Posted December 6, 2008 Share Posted December 6, 2008 I don't use mine anymore:pc:blast it with air Same here. Air is my friend on a black car. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted December 7, 2008 Share Posted December 7, 2008 I use a Ca. water blade to get the worst off then detail spray and microfiber towel. Works good ,just make sure that the blade is clean and in good shape. Link to comment Share on other sites More sharing options...
0 Adam Posted December 7, 2008 Share Posted December 7, 2008 I agree. I have come to the conclusion that anytime you can avoid actually touching the paint with anything, you have just eliminated another opportunity to leave a scratch. The Junk Man is right, avoiding touching the car is a sure way to avoid damaging the finish! Link to comment Share on other sites More sharing options...
0 chevyguy8893 Posted December 7, 2008 Author Share Posted December 7, 2008 That is a good point, it is easy, but it could be harder in the long run if it does scratch. I guess I will either have to fix my air compressor or buy a decent shop vac to blow the water off. Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted December 7, 2008 Share Posted December 7, 2008 That is a good point, it is easy, but it could be harder in the long run if it does scratch. I guess I will either have to fix my air compressor or buy a decent shop vac to blow the water off. $40 for a electric leaf blower. It can blow my cats around so water on your car is cake. Link to comment Share on other sites More sharing options...
0 Devin04 Posted February 17, 2009 Share Posted February 17, 2009 I use a Ca. water blade to get the worst off then detail spray and microfiber towel. Works good ,just make sure that the blade is clean and in good shape. Link to comment Share on other sites More sharing options...
0 crowvet Posted February 17, 2009 Share Posted February 17, 2009 I don't use mine anymore:pc:blast it with air :iagree:Master Blaster to the rescue:banana: Link to comment Share on other sites More sharing options...
0 dvalentine Posted February 18, 2009 Share Posted February 18, 2009 I don't use mine anymore:pc:blast it with air I have "Compressor Envy "...... dv Link to comment Share on other sites More sharing options...
0 Sundog Detailing Posted February 18, 2009 Share Posted February 18, 2009 Metro Vac 'n' Blo from Metropolitan Vacum is compact, light, and is a great product. Link to comment Share on other sites More sharing options...
0 dvalentine Posted February 18, 2009 Share Posted February 18, 2009 Metro Vac 'n' Blo from Metropolitan Vacum is compact, light, and is a great product. Thanks fr the tip !! It looks pretty cool !!! Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted February 18, 2009 Share Posted February 18, 2009 I have "Compressor Envy "...... dv My $39 electric leaf blower cured my envy. And it works great on leaves too! Link to comment Share on other sites More sharing options...
chevyguy8893
23 answers to this question
