jem556 Posted June 21, 2016 Share Posted June 21, 2016 I ended up with horizontal streaking on my windshield after applying the glass sealant...what is the recommended method of removing the product? Link to comment Share on other sites More sharing options...
0 Gen9Rolla Posted June 21, 2016 Share Posted June 21, 2016 You could try re-applying it and hoping it reactivates whats there/covers it up but I'm fairly sure you'll have to polish it off Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 21, 2016 Share Posted June 21, 2016 A wipedown with Glass Cleaner should work - use a waffle weave towel If you still have streaking, let me know. Link to comment Share on other sites More sharing options...
0 rrmccabe Posted June 21, 2016 Share Posted June 21, 2016 A wipedown with Glass Cleaner should work - use a waffle weave towel If you still have streaking, let me know. You mean non Adams glass cleaner right Jason? Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 21, 2016 Share Posted June 21, 2016 No I meant Adams Glass Cleaner without alcohol to start - regular glass cleaner will work just degrade the sealant slightly jem556 1 Link to comment Share on other sites More sharing options...
0 AvsBest Posted June 21, 2016 Share Posted June 21, 2016 Just to make sure: You know you have to remove the excess as indicated on the bottle right? Link to comment Share on other sites More sharing options...
0 rrmccabe Posted June 21, 2016 Share Posted June 21, 2016 No I meant Adams Glass Cleaner without alcohol to start - regular glass cleaner will work just degrade the sealant slightly OK I thought you were answering his question on how to remove it. Link to comment Share on other sites More sharing options...
0 Murk Mags Posted June 21, 2016 Share Posted June 21, 2016 Would Iso alcohol and water (1 part water, 1 part alcohol) do the trick? I used this method before polishing my car and after polishing to remove all the residue. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 21, 2016 Share Posted June 21, 2016 Yes - but you might want to reapply the sealant as IPA would probably strip it Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted June 21, 2016 Share Posted June 21, 2016 Just to make sure: You know you have to remove the excess as indicated on the bottle right? Good question. Link to comment Share on other sites More sharing options...
0 HFX Detailing Posted June 21, 2016 Share Posted June 21, 2016 Guys, I think some people are confusing two things. Removing the residue of the product as part of the applying steps. vs. Stripping Glass Sealant off completely. Which is it you are looking for @jem556? BrianT 1 Link to comment Share on other sites More sharing options...
0 jem556 Posted June 22, 2016 Author Share Posted June 22, 2016 Guys, I think some people are confusing two things. Removing the residue of the product as part of the applying steps. vs. Stripping Glass Sealant off completely. Which is it you are looking for @jem556? Well my original question was how to completely remove the product but if there are methods for only removing the banding/streaking and uneven water beading, I would certainly be interested in that as well. I followed the instructions on the bottle carefully but maybe the large windshield of a full size SUV makes it more difficult to get an even finish. Link to comment Share on other sites More sharing options...
0 AvsBest Posted June 22, 2016 Share Posted June 22, 2016 I'm still confused lol Step 1: Clay bar window with glass cleaner as lubricant Step 2: Wipe with glass towel Step 3: Apply glass sealant with microfiber applicator (same way you polish, horizontal all the way than vertical all the way) STEP 4: Remove the excess with a mist of glass cleaner (you shouldn't see any product whatesoever on the window after this step) Adam's have a video on this somewhere Link to comment Share on other sites More sharing options...
0 jem556 Posted June 22, 2016 Author Share Posted June 22, 2016 I'm still confused lol Step 1: Clay bar window with glass cleaner as lubricant Step 2: Wipe with glass towel Step 3: Apply glass sealant with microfiber applicator (same way you polish, horizontal all the way than vertical all the way) STEP 4: Remove the excess with a mist of glass cleaner (you shouldn't see any product whatesoever on the window after this step) Adam's have a video on this somewhere Maybe therein lies the problem...I interpreted the instructions to apply in one direction, wait then apply 2nd coat in other direction as meaning first right to left and then left to right. I applied both coats horizontally...just in opposite directions????. Link to comment Share on other sites More sharing options...
0 AvsBest Posted June 22, 2016 Share Posted June 22, 2016 I don't think it should matter that much but maybe the fact that the first coat cures before you put the 2nd one has something to do with it? I would think that as long as you do the 4th step you should be fine. I put a few drops on the applicator (5-6 or so I guess) I let gravity do the work I don't press on the bottle, then I go back and forth then up and down on one half of the window. Then I do the same on the 2nd half including adding more product. Let sit 10min or so then glass cleaner with the glass towel to remove the residue Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 22, 2016 Share Posted June 22, 2016 Why are you applying 2 coats of it. It has denatured alcohol in it and a 2nd application is removing the first. Apply the sealant in both directions on half the windshield before removing. If you want to strip it completely use an IPA wipe. Link to comment Share on other sites More sharing options...
0 McDuff Posted June 22, 2016 Share Posted June 22, 2016 I also have had great success with letting it sit on the windshield for a long time and then cleaning it off with the glass cleaner. It seems to me the longer it sits on the windshield the longer protection I get. I left it on my sons Volvo truck windshield for 32 hours while we cleaned the truck and it cleaned up very nice and gave him some nice beading action and blew off well on his first trip. Link to comment Share on other sites More sharing options...
0 jem556 Posted June 22, 2016 Author Share Posted June 22, 2016 Why are you applying 2 coats of it. It has denatured alcohol in it and a 2nd application is removing the first. Just following directions on the bottle... Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 22, 2016 Share Posted June 22, 2016 I just apply in both directions. When I mean "coat" I mean an application and removal. And I don't let it cure long at all, it usually only sits for a minute or so since it hazes up almost immediately. Link to comment Share on other sites More sharing options...
0 chops1sc Posted June 22, 2016 Share Posted June 22, 2016 https://www.youtube.com/watch?v=Iml8kTgvN9w Link to comment Share on other sites More sharing options...
jem556
19 answers to this question
