falcaineer Posted February 18, 2018 Share Posted February 18, 2018 My MF towels got put in the laundry with regular soap and fabric softener - not by me - can they be fixed? If so, how?! Please help!!! Link to comment Share on other sites More sharing options...
1 Wy_detailing Posted February 18, 2018 Share Posted February 18, 2018 Add a few ounces of APC to a bucket of water and let the towels sit overnight, then wash with microfiber revitalizer! Should be good to go from there Hookem06, falcaineer and TheWolf 2 1 Link to comment Share on other sites More sharing options...
0 falcaineer Posted February 19, 2018 Author Share Posted February 19, 2018 (edited) Thanks, Wyatt. I panicked, started boiling them, lost patience - what the %#×! do you do with a boiling hot DST?! Impossible to ring out - and so washed in MRB. Anyway, they're soaking now in APC and I'll rewash tomorrow in MRB. Fingers crossed. I about freaked when I found them! OK, not "about." I did. Did I mention two brightly colored, non-MF towels also found their way in the mix? Edited February 19, 2018 by falcaineer Link to comment Share on other sites More sharing options...
0 Rich Posted February 19, 2018 Share Posted February 19, 2018 Aside from the fabric softener, I don't see what the problem is unless you used powder soap. Personally, I would have just rewashed them with hot water and liquid soap and called it a day. BRZN and falcaineer 1 1 Link to comment Share on other sites More sharing options...
0 Liralen Posted February 22, 2018 Share Posted February 22, 2018 On 2/18/2018 at 5:55 PM, falcaineer said: Thanks, Wyatt. I panicked, started boiling them, lost patience - what the %#×! do you do with a boiling hot DST?! Impossible to ring out - and so washed in MRB. Anyway, they're soaking now in APC and I'll rewash tomorrow in MRB. Fingers crossed. I about freaked when I found them! OK, not "about." I did. Did I mention two brightly colored, non-MF towels also found their way in the mix? Be careful about using too hot of water or drying cycle. They can cause issues with the fibers binding and no longer being as efficient. I also have had the issue with someone washing my detail towels in error (usually my glass towels for my household use) & that person uses fabric softener (I do not like fabric softener - it is a touch/feel issue)...so good to know about using APC to get that artificial softness out of the fibers so that they will do their job properly. Link to comment Share on other sites More sharing options...
0 Rich Posted February 22, 2018 Share Posted February 22, 2018 I agree about using a hot dryer, but not the water. We boil towels. Doesn't get much hotter than that, and it wouldn't be recommended to boil them if it harmed the towels. But you don't want to put your towels in a hot dryer and over dry them for sure. Norton and Liralen 2 Link to comment Share on other sites More sharing options...
0 Liralen Posted February 22, 2018 Share Posted February 22, 2018 30 minutes ago, Rich said: I agree about using a hot dryer, but not the water. We boil towels. Doesn't get much hotter than that, and it wouldn't be recommended to boil them if it harmed the towels. But you don't want to put your towels in a hot dryer and over dry them for sure. Thanks Rich...I stand corrected on the boiling Link to comment Share on other sites More sharing options...
0 mc2hill Posted February 22, 2018 Share Posted February 22, 2018 11 hours ago, Liralen said: Be careful about using too hot of water or drying cycle. They can cause issues with the fibers binding and no longer being as efficient. I also have had the issue with someone washing my detail towels in error (usually my glass towels for my household use) & that person uses fabric softener (I do not like fabric softener - it is a touch/feel issue)...so good to know about using APC to get that artificial softness out of the fibers so that they will do their job properly. 10 hours ago, Rich said: I agree about using a hot dryer, but not the water. We boil towels. Doesn't get much hotter than that, and it wouldn't be recommended to boil them if it harmed the towels. But you don't want to put your towels in a hot dryer and over dry them for sure. Lenore is correct about the hot water. I attended a 'Microfiber 101' class at Mobile Tech Expo taught by Levi from The Rag Company. They recommended to skip the Hot setting, as MF can melt at 140F, and some hot water heaters may be set to that, or higher. I use the Hot setting for my white polishing towels without issue, but results may differ. Not sure if the towels do not heat up to that temp when they are boiled, but I know that can work to 'revive' them sometimes. Liralen 1 Link to comment Share on other sites More sharing options...
0 Rich Posted February 22, 2018 Share Posted February 22, 2018 That's what I love about this forum. We can discuss different opinions without offending anyone. Thanks for the info Michael. Liralen and mc2hill 2 Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted February 23, 2018 Share Posted February 23, 2018 What about towels that leave lint behind on the vehicle? Any recommendations on how to fix a linting issue? Link to comment Share on other sites More sharing options...
0 Rich Posted February 24, 2018 Share Posted February 24, 2018 11 hours ago, Nickfire20 said: What about towels that leave lint behind on the vehicle? Any recommendations on how to fix a linting issue? That's a good reason to boil. And be VERY careful not to wash your micros with anything terry cloth. Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted February 24, 2018 Share Posted February 24, 2018 How long do you boil them for? Im aware of the terry towel issue, and would never let that happen. My issue is with 3 towels from another company that are similar to the triple softs. They were a little pricey and I can’t seem to figure them out Link to comment Share on other sites More sharing options...
0 Liralen Posted February 25, 2018 Share Posted February 25, 2018 On 2/22/2018 at 7:07 AM, mc2hill said: Lenore is correct about the hot water. I attended a 'Microfiber 101' class at Mobile Tech Expo taught by Levi from The Rag Company. They recommended to skip the Hot setting, as MF can melt at 140F, and some hot water heaters may be set to that, or higher. I use the Hot setting for my white polishing towels without issue, but results may differ. Not sure if the towels do not heat up to that temp when they are boiled, but I know that can work to 'revive' them sometimes. Woohoo....thanks for the confirmation. The key in this is like you stated, the overall temperature. Most people will not have their hot water set that high, as it is not recommended and can actually burn you. I kind of go with the rule, if I can put my hand under the water and it don't think "crap that is hot" and don't think "crap is this water ever going to get hot', then the temperature setting must be just right....and then it would be safe to wash on hot. My problem with some of my microfiber towels and as well the wool wash mitts is the pine needles...the pine needles hide out in the roof ditch and microfiber towels pick them up so quickly, have to constantly check to make sure none got picked up in the towel. mc2hill 1 Link to comment Share on other sites More sharing options...
0 Norton Posted March 5, 2018 Share Posted March 5, 2018 (edited) According to the "BOILING YOUR TOWELS" section FAQ: "How do I take care of my microfiber towels?"... Over time your microfiber may become contaminated past the point it can be completely cleaned using traditional methods. Typically this will present itself during use - drying towels will begin to feel less absorbent. Plush towels may lint slightly or smear products more than remove them. This is an indication that the fibers are 'full' either from residues deposited during use or things like fabric softener accidentally introduced during cleaning. In any event, if your towels begin to loose their performance or just don't feel as good as they did new boiling is the solution, the last resort, to bring them back. NOTE: this process applies only to towels and microfiber without foam cores or backing. Never boil pads or applicators. - Fill a large cooking pot approximately 2/3rd full of water and bring to a boil - Add approximately 1-2oz of distilled white vinegar per gallon of water and stir - Place a few of the towels to be treated into the pot, maintaining a slow boil - Stir continuously with a large spoon, avoid letting the towels rest against the bottom or sides for too long - After about 60-90 seconds in the boil, remove the towels using tongs and rinse under cool water - Wash using the "Regular Cleaning" guidelines outlined earlier and they should be as good as new. NOTE: Should boiling fail to bring absorbancy to a towel or the towel continues to lint then you are most likely dealing with a towel at the end of its lifespan. Retire the towel to less important tasks and replace with a new one for future use. FWIW, it's worked as advertised when I've boiled mine. I usually wash in hot water, but my water heater is set to ~125-130 degrees. Edited March 5, 2018 by Norton Nickfire20 and falcaineer 1 1 Link to comment Share on other sites More sharing options...
0 rondre Posted April 3, 2018 Share Posted April 3, 2018 I know this is an older post but I've been reading up on caring for microfiber and the temperature thing seems to get to me. When reading my dryer temps it claims the following: Low 120-130 degrees Medium 130-140 degrees Medium High 140-160 degrees So what doesn't make sense to me is the boiling part. If it's ok to boil you towels which would mean 212 degrees or somewhere close to that if cooled slightly, that's way hotter than even the high of 160 degrees of my dryer. I understand the boiling method is only a few minutes while a dry cycle is considerably longer so is it the time at higher temps that's the issue? Does microfiber really melt at 140 degrees as others have mentioned and if so then is that for a certain period of time since many have reported boiling helps their clogged pieces? Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted April 3, 2018 Share Posted April 3, 2018 I have been wondering the same thing for a while now. Every company has different recommendations. Griots says to wash on hot and hang dry. TRC says cold, tumble dry, and dont boil. I have boiled a linty towel before, and it has helped but not fixed the problem...this towel has become my GnG towel, because it does not lint when wet. Im currently fighting with Griots because my PFM drying towel doesn’t dry any more, and is less than a year old and I probably only have used it 6-8 times. So i may boil it. ?♂️?♂️?♂️ Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted April 4, 2018 Share Posted April 4, 2018 I would say that boiling doesn’t dry out the fibers like a dryer would. It’s not just the temp, but the type of heat as well. Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted April 4, 2018 Share Posted April 4, 2018 (edited) Im also now wondering, if leaving towels in the garage year round could be bad...mainly summer time? ?♂️?♂️ Edited April 4, 2018 by Nickfire20 Link to comment Share on other sites More sharing options...
0 Beemer Posted April 4, 2018 Share Posted April 4, 2018 7 minutes ago, Nickfire20 said: Im also now wondering, if leaving towels in the garage year round could be bad...mainly summer time? ?♂️?♂️ Not sure if you're joking or not but I'll bite: Summer will not hurt your towels. Nickfire20 1 Link to comment Share on other sites More sharing options...
0 falcaineer Posted April 5, 2018 Author Share Posted April 5, 2018 It's been a while, but I'll bring this back to my original post with a follow-up... Soaked them overnight in a couple ounces of APC in ~1-2g of water, held down with the grit guard. Then washed on warm with MBR, extra rinse cycle, and air dried. They seem to be OK after using them with RW and after a detail session. For the record, it wasn't much fabric softener or regular detegent, so more softener and/or liquid detergent, or powder for that matter, may take more/ruin the towels. Link to comment Share on other sites More sharing options...
0 Rich Posted April 7, 2018 Share Posted April 7, 2018 On 4/4/2018 at 3:23 PM, Beemer said: Not sure if you're joking or not but I'll bite: Summer will not hurt your towels. NOT necessarily true. If you keep your towels in sealed plastic containers, they can collect condensation in the hot summer months and then grow mold on your towels. In which case, you might as well toss them in the trash. In the winter, same thing can happen, but even worse, MICE are looking for nesting materials. I lost a bunch of towels last year for that reason. First time. Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted April 8, 2018 Share Posted April 8, 2018 22 hours ago, Rich said: NOT necessarily true. If you keep your towels in sealed plastic containers, they can collect condensation in the hot summer months and then grow mold on your towels. In which case, you might as well toss them in the trash. In the winter, same thing can happen, but even worse, MICE are looking for nesting materials. I lost a bunch of towels last year for that reason. First time. ?♂️ Link to comment Share on other sites More sharing options...
0 Hookem06 Posted April 11, 2018 Share Posted April 11, 2018 On 4/6/2018 at 10:55 PM, Rich said: NOT necessarily true. If you keep your towels in sealed plastic containers, they can collect condensation in the hot summer months and then grow mold on your towels. In which case, you might as well toss them in the trash. In the winter, same thing can happen, but even worse, MICE are looking for nesting materials. I lost a bunch of towels last year for that reason. First time. Same here. I threw about 30 brand new towels away, stored in plastic containers in my shop. Link to comment Share on other sites More sharing options...
falcaineer
22 answers to this question
