Jlinn1989 Posted September 7, 2020 Share Posted September 7, 2020 I’ve seen how well brilliant glaze cuts off gas film and dirt on the inside of the windshield but is it safe to use the brilliant glaze on a tinted window or windshield? Link to comment Share on other sites More sharing options...
0 RayS Posted September 7, 2020 Share Posted September 7, 2020 My side windows have a tint film applied I have used Brilliant Glaze on them for about 3 years with no ill effect. There are many different types of window tint, so my recommendation is to always find a place to do a test spot and make an educated decision. falcaineer 1 Link to comment Share on other sites More sharing options...
0 BRZN Posted September 8, 2020 Share Posted September 8, 2020 Factory tinted glass go ahead, no problem. I don't use Brilliant Glaze on tint film. The solvent in the Brilliant Glaze will break down the adhesive holding the film to the glass. Ray, I'd say you've been pretty lucky to this point! falcaineer and kaj41354 2 Link to comment Share on other sites More sharing options...
0 RayS Posted September 8, 2020 Share Posted September 8, 2020 11 hours ago, BRZN said: Factory tinted glass go ahead, no problem. I don't use Brilliant Glaze on tint film. The solvent in the Brilliant Glaze will break down the adhesive holding the film to the glass. Ray, I'd say you've been pretty lucky to this point! Or the 3M UV tint with security is just that good. I do agree that I wouldn't use any solvent type of a product on the average film tint and especially not the lower end that you can see marks on within a week of application. Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted September 11, 2020 Share Posted September 11, 2020 As Dave has mentioned, I don't use Brilliant Glaze on aftermarket tint, only if I need to remove some really stubborn grease, animal saliva, etc in a spot or two. I never apply it to the edge of the window where the tint film ends for the very reason Dave mentions - I do not want it to weaken the adhesive at the edge. Essentially I treat window tint just like vinyl graphics, pinstripes, and racing stripes on paint, I stay away from the edges on those too! One mist of our green Glass Cleaner with a clean Green Glass Towel is usually enough to get a tinted window looking great. The other potential issue with tint film is that it can be much easier to scratch than plain glass, so if you have even one little piece of grit or dirt in your applicator if you were to apply Brilliant Glaze on tint, you could then scratch it. I did this on my old Trailblazer SS that had some faded and failing tint, as I wanted to see if I could do anything to bring it back a little, and I ended up using too much pressure with the applicator, which happened to catch a piece of dirt from the felt portion of the window track and then scratch the tint. falcaineer 1 Link to comment Share on other sites More sharing options...
Jlinn1989
4 answers to this question
