We have learned proper lighting is important when chasing swirls. I have been using a pair of 500w halogen lamps on a stand for several years. These work great, and are nice to be around in the winter, but they are brutal in the warmer months. I have seen the LED work lights (pic below) with a similar setup. They are much cooler to work around, but the light is not as bright as the halogens and do not show imperfections as well.
I have seen a few different DIY LED light stand builds on other forums, and after seeing Sizzle Chest’s setup I decided to give it a try. Most of the parts are fairly inexpensive, using lightweight photography equipment, but the bulbs are pricey!
This stand has a minimum height of 53”, and a maximum of 100”. It works great for hoods, roofs, and trunks, but just OK for sides. For that reason I am looking at 2 other stands:
The light ‘head’ is the simple part. It is a double mount bracket, with an on/off switch for each lamp, and a short 9’ cord. This just slides over the top of the stand and is tightened down. There are other fiddly bits on the bracket, but as I am not a photographer, I have no idea what they are for.
So far so good, less than $30 (light head $10.99 + stand $15.99).
Now about the light bulbs: There are lots and lots of different types of LED light bulbs out there but to replicate the sun you need a daylight bulb – somewhere around 5000 kelvin on the color temp scale.
I was able to find my bulb at Lowe’s, but it seems to be an item they are discontinuing –
It is a size PAR38, 23W (120W equivalent), 5000K, Daylight, Dimmable floodlight bulb. The only store in my area that carried them was the near my house and I picked up 4. Even on ‘closeout’ they were $25.99 EACH! The upside to these bulbs is they have a life of 25,000 hours, so unless you break them, they should last a long, long time.
Speaking of breaking them, this setup is very top heavy. The first time I used it I had the stand set at about 6’, bumped into it, and it fell on to the trunk of the A8 I was polishing! After a few choice words, my stomach dropped when I saw white marks on the paint! The heat fins from the bulb had marked the paint. Luckily it was just paint transfer and was quickly removed with the polisher, with no further damage to the car or the lights. After that I decided to look for a simple fix and found it at a local thrift store:
Discarded ankle weights!
I paid $3 for one at the thrift store, but they are about $17 new (I bought a pair when I got tired of driving around to the Goodwill’s). This is one I found (they only had one), and it easily fits over the upright part of the stand, and provides just enough weight to offset the bulbs. I removed 2 of the weight packs, so it is probably at 4 pounds. The plus with these is they wrap around the light stand when it is folded.
So now we are up to $80
Stand $15.99
Light head 10.99
2 LED bulbs 50.00
Weights 3.00
Not too bad and much cheaper than a pair of the LED work lights with a stand.
Here is what you get:
So how well do they work?
A shot of both lights on full: The halogen mounting bracket puts them farther apart than the LED bracket, but that is not really an issue:
LED:
Halogen:
Why are they better then Halogens?
Front of lights
vs.
Now the temp at the back:
vs.
Other options:
You could add a boom to put the light over a flat surface (hood, roof, etc.)
Conclusions:
I really enjoy working with the LED lights. They are more comfortable to work around, and I prefer the whiter light they produce. I think they show more defects too.
They also draw less power, so no more worry about tripping a fuse when using the lights and the polisher.
Please feel free to ask questions or suggest improvements. I am not a photographer, nor an electrical engineer, so there are probably better ways to do this!
mc2hill
I started with a stand that included a carrying bag - http://www.amazon.com/gp/product/B008DYHRH4?
psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
This one that has a minimum of 33”, max of 80” - http://www.amazon.com/dp/B003PEUA30/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2W8PMFWAIX1V2&coliid=I2S0K4VP91Z62V&psc=1
Or this one that is much shorter – Min 17”, max 40”
http://www.amazon.com/Neewer-Collapsible-Aluminium-Photography-Portrait/dp/B00X5GCG12/ref=sr_1_5?s=photo&ie=UTF8&qid=1433004584&sr=1-5
The second stand includes a ‘stud’ that is attached to the lower leg to allow a second light head to be attached. The downside is the stud must be removed to collapse the stand. There are clamps available to allow you to mount a light head almost anywhere and if I go with the first stand I would add one of these – http://www.amazon.com/dp/B00355GFMO/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2W8PMFWAIX1V2&coliid=IB3IMSHH6UKOR
http://www.amazon.com/dp/B00HZUVX8G/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2W8PMFWAIX1V2&coliid=I1UB3VZ74Z4A4V
http://www.lowes.com/pd_150661-75774-LPAR3814005KLEDG5___?productId=50107550&pl=1&Ntt=led+par38+daylight
Stand $15.99
Light head 10.99
2 LED bulbs 50.00
Weights 3.00
LED:
Halogen:
Front of lights
vs.
vs.
Other options:
Conclusions:
43 answers to this question
