IAcamoprincess01 Posted September 28, 2016 Share Posted September 28, 2016 Hi I have a suggestion about a new wheel woolie. Of the 3 offered only the smallest and shortest handle one works for my rims, but because of the short handle my hand cramps up using it. It would be great if you guys came out with one that was the size of the smallest one but the length of the handles like the other two. So basically a long handled small wheel woolie. Anyone else agree? Thanks Rich 1 Link to comment Share on other sites More sharing options...
Kingsford Posted September 28, 2016 Share Posted September 28, 2016 I believe Adam's only carries the 1 Wheel Woolie that is a 45* Angle. However, if you are referring to the one that has a handle thinner than a pencil then I'd have to agree. But seeing as Wheel Woolies are made by another company, this probably won't go anywhere. Link to comment Share on other sites More sharing options...
IAcamoprincess01 Posted September 28, 2016 Author Share Posted September 28, 2016 Too bad...looks like I will have to tape something to it to make the handle longer. Maybe a dowel rod ? Link to comment Share on other sites More sharing options...
Mariner Posted September 28, 2016 Share Posted September 28, 2016 Good point. Also the handle gets slick and tends to rotate in my hand, along with the cramps. But the tool itself works great at getting in the wheels, but the handle needs some modification. Link to comment Share on other sites More sharing options...
Gen9Rolla Posted September 29, 2016 Share Posted September 29, 2016 You could probably get a small diameter piece of PVC and just glue/tape the woolie to the PVC. If you do attach anything to it, I would make sure you cover up the mating point really well to avoid potentially damaging your wheels from the added piece Link to comment Share on other sites More sharing options...
FrozenWS6 Posted September 29, 2016 Share Posted September 29, 2016 (edited) Good point. Also the handle gets slick and tends to rotate in my hand, along with the cramps. But the tool itself works great at getting in the wheels, but the handle needs some modification.Great tool and I use it a lot.Though, I have the same issue. Because of the red grip spinning it's hard on my arthritic hands. Edited September 29, 2016 by FrozenWS6 Link to comment Share on other sites More sharing options...
IAcamoprincess01 Posted September 29, 2016 Author Share Posted September 29, 2016 You could probably get a small diameter piece of PVC and just glue/tape the woolie to the PVC. If you do attach anything to it, I would make sure you cover up the mating point really well to avoid potentially damaging your wheels from the added piece Thanks for the suggestion...may have to try it Link to comment Share on other sites More sharing options...
Kingsford Posted September 29, 2016 Share Posted September 29, 2016 If the red grip spins, get some shrink wrap and wrap some of the red grip and the stick together. Link to comment Share on other sites More sharing options...
wely324 Posted September 29, 2016 Share Posted September 29, 2016 (edited) A long handle thin wheel whoolie would be nice to get behind the brake calipers to get to the back edge of the wheel... I have the the Adam's angled wheel whoolie, unfortunately it is my least favorite wheel whoolie as I don't like the angle it has. It has become a specialty brush for certain wheels that benefit from the angle. Edited September 29, 2016 by wely324 Link to comment Share on other sites More sharing options...
avimore Posted September 29, 2016 Share Posted September 29, 2016 Are Adam's bringing back the 3 different sized (non-angled) wheel woolies? The only one I could find online is the angled one. Link to comment Share on other sites More sharing options...
IAcamoprincess01 Posted September 30, 2016 Author Share Posted September 30, 2016 Are Adam's bringing back the 3 different sized (non-angled) wheel woolies? The only one I could find online is the angled one. I wish they would.....the new one will not fit in my rims to clean the barrel of the wheel....absolutely no way...I love the length of the handle though. Link to comment Share on other sites More sharing options...
gma3748 Posted September 30, 2016 Share Posted September 30, 2016 Have the same issues as the rest of you. It just doesn't fit either set of wheels my vehicles have. Hope they come out with the trio again. Would definitely pick up a set! IAcamoprincess01 1 Link to comment Share on other sites More sharing options...
Kingsford Posted September 30, 2016 Share Posted September 30, 2016 (edited) Guys, again... Adam's does not make the Wheel Woolies, they are just a reseller. Google Wheel Woolies and you'll find about 100 different places you can purchase the 3 pack. The company that makes Wheel Woolies make the 45* brush exclusively for Adam's, the 3 pack is available other places. Edit: I believe I can post this link without breaking a forum rule. They may be cheaper else where but they are available on Amazon. https://www.amazon.com/ABN-WBMF-CKIT-Wheel-Woolies-3-piece/dp/B005NRRNVO Edited September 30, 2016 by Kingsford Mariner 1 Link to comment Share on other sites More sharing options...
LT1xL82 Posted September 30, 2016 Share Posted September 30, 2016 It has been a while since I researched this...but I believe there are 2 different 3 piece sets. IIRC, one of the three brushes is a slightly different size in one set from the other. Link to comment Share on other sites More sharing options...
SumBeach35 Posted September 30, 2016 Share Posted September 30, 2016 Good point. Also the handle gets slick and tends to rotate in my hand, along with the cramps. But the tool itself works great at getting in the wheels, but the handle needs some modification. I agree, my hand cramps up quite a bit using the wheel woolie. Been seriously considering getting the turbo stick once I get a new cordless drill. Link to comment Share on other sites More sharing options...
DeDonDeRosa Posted November 8, 2016 Share Posted November 8, 2016 (edited) Hated how the angle of the wheel woolie would cramp my hand real bad and was kinda annoying to use. I ended up heating it up with a heat gun and bending it straight and now i really love using it Edited November 14, 2016 by DeDonDeRosa Mariner, ocdrifter and nunzimouse 3 Link to comment Share on other sites More sharing options...
HFX Detailing Posted November 8, 2016 Share Posted November 8, 2016 I love the angle, and use the spin to my advantage....only thing I wish is I had a thinner one for extremely low clearances between brake calipers and rim. I end up having to move the vehicle, or get the missed spots later. Link to comment Share on other sites More sharing options...
ocdrifter Posted November 12, 2016 Share Posted November 12, 2016 Haha I thought the cramps only happened to me, I added a rubber grip to mine to make it a little thicker and that helped more than not having a grip. Link to comment Share on other sites More sharing options...
Lance99 Posted November 29, 2016 Share Posted November 29, 2016 I bought the wheel woodies 3 pack, and the middle sized one is the best. It would be awesome if the handle was longer. The smallest is best to be saved for the interior. For wheels I find it useless. The biggest one is good only if you don't have big brakes. The best thing is that there is no splatter, like EZ/Speed Master. Link to comment Share on other sites More sharing options...
dancingdan42 Posted November 29, 2016 Share Posted November 29, 2016 I bought the wheel woodies 3 pack, and the middle sized one is the best. It would be awesome if the handle was longer. The smallest is best to be saved for the interior. For wheels I find it useless. The biggest one is good only if you don't have big brakes. The best thing is that there is no splatter, like EZ/Speed Master. What do you use the small one for on the interior? Asking for a friend... haha Link to comment Share on other sites More sharing options...
detailingislife Posted November 30, 2016 Share Posted November 30, 2016 I love using the wheel woolie, it works great on not so bad brake dust and dirt build up. But, if you try and use it on a vehicle with excessive brake dust thats been "baked" on, it has no power. It would be nice if Adam's released a stiff bristle woolie to really agitate heavy buildup behind the wheel. avimore 1 Link to comment Share on other sites More sharing options...
shane@detailedreflections Posted November 30, 2016 Share Posted November 30, 2016 I love using the wheel woolie, it works great on not so bad brake dust and dirt build up. But, if you try and use it on a vehicle with excessive brake dust thats been "baked" on, it has no power. It would be nice if Adam's released a stiff bristle woolie to really agitate heavy buildup behind the wheel. I agree. A stiffer option to work on wheels that aren't well maintained would be great. Working on maintained wheels is rarely the challenge. It's ones that haven't been done in a long time or regularly. detailingislife 1 Link to comment Share on other sites More sharing options...
Dan@Adams Posted November 30, 2016 Share Posted November 30, 2016 I love using the wheel woolie, it works great on not so bad brake dust and dirt build up. But, if you try and use it on a vehicle with excessive brake dust thats been "baked" on, it has no power. It would be nice if Adam's released a stiff bristle woolie to really agitate heavy buildup behind the wheel. I agree. A stiffer option to work on wheels that aren't well maintained would be great. Working on maintained wheels is rarely the challenge. It's ones that haven't been done in a long time or regularly. The Turbo Stick is perfect for these instances Link to comment Share on other sites More sharing options...
shane@detailedreflections Posted November 30, 2016 Share Posted November 30, 2016 The Turbo Stick is perfect for these instances I actually have an older turbo stick. I haven't used the newer version. It is an improvement over the wheel whoolies. Link to comment Share on other sites More sharing options...
Chris@Adams Posted November 30, 2016 Share Posted November 30, 2016 Check out Today's Daily SpecialIt won't be here tomorrow.Adam's Wheel Woolie$24.99Sale $20.99http://adamspolishes.com/adam-s-wheel-woolie.html Link to comment Share on other sites More sharing options...
