65 L76 Posted August 17, 2021 Share Posted August 17, 2021 Coming home after 3 weeks away I found I have dried tree sap down the side of my car. What’s the best way to remove it? IPA, goo gone, clay bar or clay mitt? Help!! Link to comment Share on other sites More sharing options...
0 falcaineer Posted August 18, 2021 Share Posted August 18, 2021 3 hours ago, 65 L76 said: Coming home after 3 weeks away I found I have dried tree sap down the side of my car. What’s the best way to remove it? IPA, goo gone, clay bar or clay mitt? Help!! I recommend TAR. It might take a few applications but it should work well. https://adamspolishes.com/products/adams-tar Mantis 1 Link to comment Share on other sites More sharing options...
0 Norton Posted August 18, 2021 Share Posted August 18, 2021 Is your car ceramic-coated? If so, try washing it. (This worked perfectly on my ceramic-coated black Shelby after having maple sap misted onto it from a nearby tree weeping it into a steady breeze in thehot August sun. The ease with which it came off made me a ceramic believer.) If not, I recommend TAR and clay, as necessary. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 18, 2021 Share Posted August 18, 2021 TAR is a great choice, if you don't have any you can use also the top solvent (before shaking) of Brilliant Glaze. Link to comment Share on other sites More sharing options...
0 07stanggt Posted August 18, 2021 Share Posted August 18, 2021 If you dont have anything else as mentioned above, Isopropyl Alcohol works awesome. Pour small amount on a microfiber towel, let it sit on the sap for 10/15 seconds, wipe carefully Link to comment Share on other sites More sharing options...
0 RayS Posted August 18, 2021 Share Posted August 18, 2021 If the references above don't work or If the sap has dried on, you can use plenty of lube with a plastic razor blade. I've found that Waterless Wash works well as a lube for dried tree sap. Link to comment Share on other sites More sharing options...
0 Mantis Posted August 23, 2021 Share Posted August 23, 2021 Tree sap sucks no matter what you use. You most likely are gonna have to polish after removing it. Tar is the way to go. But be gentle with it to minimize damage. Link to comment Share on other sites More sharing options...
0 mc2hill Posted August 23, 2021 Share Posted August 23, 2021 I like very thick hand sanitizing gel - essentially a easy way to let Isopropyl Alcohol dwell on the sap. I let that sit for a minute or so, then remove with a 'work' MF towel. If it is stubborn apply the gel, then carefully use a plastic razor blade to remove it. Link to comment Share on other sites More sharing options...
65 L76
