bosco1 Posted June 21, 2016 Share Posted June 21, 2016 I'm sure this has been answered before but I couldn't find it. What's the Difference betwee Waterless & Rinseless and when should you use one or the other? Thanks... Link to comment Share on other sites More sharing options...
0 chops1sc Posted June 21, 2016 Share Posted June 21, 2016 My understanding is this; Rinseless is used with a bucket of water and wet towels similar to the GDWM (solution in the bucket), Waterless is used with dry towels and no water (sprayed on the car). There are other uses. Link to comment Share on other sites More sharing options...
0 Texas Moe Posted June 21, 2016 Share Posted June 21, 2016 I haven't used the new Waterless Wash so I'm answering based on what others have said on this forum. The two products can work almost exactly the same as a 'spray and wipe' cleaner (mixing the RW at 16:1). Many folks will tell you that WW works better as a pre-treat for bugs because it has more cleaning solvents in it. They both now add some shine as you're cleaning (old WW didn't) so that part is equal. The case for WW: Ready to use (RTU) right out of the bottle, better on bugs, no mixing by hand The case for RW: Cheaper because it can be diluted (even though you have to mix by hand), many more uses (detail spray, clay lube, pre-treat, bucket wash) Ricky Bobby and 370ZRyan 2 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 21, 2016 Share Posted June 21, 2016 I haven't used the new Waterless Wash so I'm answering based on what others have said on this forum. The two products can work almost exactly the same as a 'spray and wipe' cleaner (mixing the RW at 16:1). Many folks will tell you that WW works better as a pre-treat for bugs because it has more cleaning polymers in it. They both now add some shine as you're cleaning (old WW didn't) so that part is equal. The case for WW: Ready to use (RTU) right out of the bottle, better on bugs, no mixing by hand The case for RW: Cheaper because it can be diluted (even though you have to mix by hand), many more uses (detail spray, clay lube, pre-treat, bucket wash) Best post yet - I fixed in bold above, there shouldn't be any solvents in either product, the cleaning agents are polymers - again, that was true about the old WW - the new WW is more similar of a formula to a diluted Rinseless Wash product, which gives you all the positive qualities about a diluted rinseless but its for the guys that buy a RTU product Point is if you do rinseless washes and if you are already seeing great results with diluted rinseless wash being used as a spray and wipe (among other uses) just stick with it - the WW has always been for the people who want a RTU product for that one specific task (spray and wipe) Texas Moe 1 Link to comment Share on other sites More sharing options...
0 Texas Moe Posted June 21, 2016 Share Posted June 21, 2016 Best post yet - I fixed in bold above, there shouldn't be any solvents in either product, the cleaning agents are polymers - again, that was true about the old WW - the new WW is more similar of a formula to a diluted Rinseless Wash product, which gives you all the positive qualities about a diluted rinseless but its for the guys that buy a RTU product Thank you for the correction. It will be interesting to see if people think the new WW is still better than RW as a pre-treatment for bugs if they're now more chemically similar. Link to comment Share on other sites More sharing options...
0 Rich Posted June 21, 2016 Share Posted June 21, 2016 The Waterless Wash is a lifesaver if you have no access to water and need to clean your car, like at a car show. Or if you get caught in a an unexpected rainstorm and don't want to have to wash your car all over again. I've used it many times. Great product. Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 21, 2016 Author Share Posted June 21, 2016 When did the waterless formula change? I'm not sure which one I have but I bought a gallon. It's been a couple months ago at least. The Rinseless I just purchased this week. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 21, 2016 Share Posted June 21, 2016 (edited) Waterless was like 2 weeks ago you have the previous version - again I don't know how chemically similar or dissimilar they are as not much has been discussed but basically the new formula does add shine which is similar to diluted Rinseless Rinseless also can be taken to car shows just toss a couple gallons of water and an ounce in a bucket with gamma seal lid with about 8 towels and you can do a full wash at the show very safely Edited June 21, 2016 by Ricky Bobby bosco1 1 Link to comment Share on other sites More sharing options...
0 AvsBest Posted June 21, 2016 Share Posted June 21, 2016 I'd add that rinseless is safer than waterless when it gets beyond the "only dusty" dusty stage. You can get away with "lightly dirty" or maybe even medium dirty with rinseless bosco1 1 Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 21, 2016 Author Share Posted June 21, 2016 Is there a video for Rinseless? So if I dilute it I can use it just a waterless. Spray & wipe??? Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 21, 2016 Share Posted June 21, 2016 Yes diluted 16:1 is the most popular dilution for "spray and wipe" like Detail Spray, Waterless Wash, etc - there was a video with Dylan and VW van floating on YouTube bosco1 1 Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted June 21, 2016 Share Posted June 21, 2016 Yes diluted 16:1 is the most popular dilution for "spray and wipe" like Detail Spray, Waterless Wash, etc - there was a video with Dylan and VW van floating on YouTube Here is the video mentioned. Keep in mind this is for the concentrated Rinseless Wash, not our new Waterless Wash formula: https://www.youtube.com/watch?v=v7dG0k0Aq-Q Link to comment Share on other sites More sharing options...
0 chupr0kabra Posted June 21, 2016 Share Posted June 21, 2016 I'm glad I saw this thread, because I've been wondering the same thing for a while. Good information in here! I've been a big fan of rinseless wash products for a couple years (when I run out of the stuff I have now, I promise to give Adams a try), and I purchased some Adams Waterless a while back for quick garage queen wipedowns and spot treatments for bug and bird bombs. I realize it's cheaper to dilute rinselss as a pre-soak, but I just feel a little safer using Waterless in conjunction with my rinseless solution. Plus, this method works well for me, so I'm not keen to change it! -Mike Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 21, 2016 Author Share Posted June 21, 2016 (edited) Tks Ricky Bobby... Edited June 22, 2016 by bosco1 Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 21, 2016 Author Share Posted June 21, 2016 Tks Dan Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 22, 2016 Author Share Posted June 22, 2016 (edited) Here is the video mentioned. Keep in mind this is for the concentrated Rinseless Wash, not our new Waterless Wash formula: https://www.youtube.com/watch?v=v7dG0k0Aq-Q After watching the video using the concentrated Rinseless it's alittle 'Involved'. I'm thinking for myself I probably don't need both. If I dilute the Rinseless it's more cost effective than Waterless as you guys mentioned and basically doing the same thing. I can see doing as the video shows from time to time with the concentrated, using indoors during a bad winter etc...Think I'll dilute some of my Rinseless and use it as Waterless. Thanks guys for all your help. Edited June 22, 2016 by bosco1 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 22, 2016 Share Posted June 22, 2016 ^no worries and yea it's the more economical option - many of us do Rinseless washes when it's too hot out (can do it in your garage) or in winter to get out of the elements so it's something to try in the future. Trust me it's quicker than a traditional wash once you hone in your technique. bosco1 1 Link to comment Share on other sites More sharing options...
0 AvsBest Posted June 22, 2016 Share Posted June 22, 2016 1:30 hours for my 2 bucket wash vs 20 min rinseless wash and no set up/putting everything away required. Let me tell you that if the car qualifies for rinseless, it's gonna be rinseless. Not sure how involved it is: 1) just put 2oz in a bucket, 2) let your double/triple soft soak in it for 30 sec. 3) Wipe on panel with only 1 pass per line sorta speak (no back and forth over the same area) 4) Use dry other double/triple soft towel to dry and done (I use great white drying towel personally) mc2hill and bosco1 2 Link to comment Share on other sites More sharing options...
0 bosco1 Posted June 22, 2016 Author Share Posted June 22, 2016 1:30 hours for my 2 bucket wash vs 20 min rinseless wash and no set up/putting everything away required. Let me tell you that if the car qualifies for rinseless, it's gonna be rinseless. Not sure how involved it is: 1) just put 2oz in a bucket, 2) let your double/triple soft soak in it for 30 sec. 3) Wipe on panel with only 1 pass per line sorta speak (no back and forth over the same area) 4) Use dry other double/triple soft towel to dry and done (I use great white drying towel personally) True, I will definitely try it. Thank you AVS...I guess it just seemed alittle Unorthodox.. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 22, 2016 Share Posted June 22, 2016 Waffle weave to dry is easiest and best way when rinseless washing - the 16x24 size of the "waterless wash towel" works great for this put multiple towels in the bucket and you dont even have to do anything but wring them out after using all 8 sides and launder with the rest of your towels - very easy bosco1 1 Link to comment Share on other sites More sharing options...
0 ledger64 Posted June 22, 2016 Share Posted June 22, 2016 If your going to do rinseless might as well put down some h2oGG while you are at it. bosco1 1 Link to comment Share on other sites More sharing options...
0 mc2hill Posted June 25, 2016 Share Posted June 25, 2016 True, I will definitely try it. Thank you AVS...I guess it just seemed alittle Unorthodox.. I have been doing rinseless washes for about 7 years, but it did take some time to wrap my head around it - "What, I am going to wash the car, but NOT use a hose?". Now I rarely wash with Car Wash Shampoo! This is great for older cars where rusting is a concern, and, as the other said, works well inside the garage on a hot day. bosco1 and LT1xL82 2 Link to comment Share on other sites More sharing options...
bosco1
22 answers to this question
