Clay lube ... so many options
MikeSoFlo
Part 1. What are you all using for clay lube?
Part 2. Do you change what you are using for lube based on what you do after?
Here's what I mean, I usually use DS to lube my clay bar. I've been reading and watching videos with people saying that if you plan on doing a paint correction you should NOT use DS because it would add a layer over the paint and it could effect the pads and polishes. Is the answer then hit the car with a 50/50 ISO mix after the cay and DS and then paint correct? Use something else as lube? I've seen people use soap and water from the wash bucket. How about something like Rinseless Wash or ONR?
Looking to see what everyone else is doing and if you change you clay lube based on what you are doing after the clay process.
24 answers to this question
I use DS without any issue at all. Adam demos this in all of his videos and at clinics in person,, so if it's good enough for him, it's good enough for me. If it adds any layer at all, it's extremely minimal since DS contains a small amount of carnuba, but the polish will make quick work of that and you won't even notice. If you don't have DS, I've heard WW or diluted RW will work, but I've never tried. I also tend to clay without drying the car and use the residual water for extra lubricity.
Edited by falcaineer
If you’re gonna do a paint correction, save yourself some money and product. Just use the soap and water from your bucket with your clay. It’s quick and saves time AND money!
2 minutes ago, MikeSoFlo said:
... Rinseless seems like a more potent version of Waterless, right?
They are two different formula's, but Rinseless Wash is the concentrated one.  Rinseless Wash diluted to waterless wash strength (2+ oz RW in 16 oz bottle) is not exactly the same as Waterless Wash, but does they same thing.
On 8/4/2018 at 8:10 AM, MikeSoFlo said:
I brought home some WW. I'm going to try that this weekend and see how the clay process works with it.
Reports are Waterless Wash can be too slick for claying, but I have not used it for that purpose.  Let us know what you find!
So I used Waterless Wash and a Clay Mitt this weekend with very good success. I got the mitt very wet with the WW and then sprayed 2'x2' sections at a time with the WW. With very little pressure, I was able to effectively clay the car.  I found the mitt gliding nicely over the vehicle and I could feel the containments being lifted off. The first few passes were rough but the more I passed, the smoother it got. I also didn't notice the mitt laying down any extra marks in the paint. I did end up passing over the car with an SK (that was my plan all a long) but I didn't see the mitt marring the paint.
I can't say WW worked any better or worse than DS but WW is cheaper than DS and if I dilute RW it will be even cheaper, I think WW/RW will be my go to for claying for now on.
Here's a before and after of a bird bomb that I was working on this weekend using the above process. The bomb etched the clear coat pretty bad. It's not 100% gone as I would have needed to wet sand the area but it's 90% gone and really can't be seen unless you are looking for it.
Process:
Cleaned with Ultra Foam Shampoo
Dried with a Great White Drying Towel
Clayed with a Mitt and Waterless Wash
Heavy Cutting Compound on a Microfiber Pad
Cutting Compound on a Foam Pad
Finishing Polish on a Foam Pad20180804_232653.thumb.jpg.443fcc282e0b53e579c0bb4cfa954ee0.jpg20180804_232703.thumb.jpg.7b9025d04d72dc4c85e732de6a5bc65e.jpg
Edited by MikeSoFlo
7 hours ago, Nickfire20 said:
Looks great,  in the future you could also, re foam the car and clay utilizing the foam,  or just leave the car wet, and use your WW or DS, as the water will provide some extra lube,  then rinse the whole car, then dry.
That's how I do it as well
+2 for me as well in regards to using foam. Has worked well for me
On 8/3/2018 at 12:34 PM, Editguy said:
For those using RW for lube what ratio are you diluting it to? 16:1 or 32:1?
There’s a RW dilution chart in here somewheres. Good info if you can find it.
Found it!
Edited by GXPaycheck
Process:
 That’s awesome. I tried getting some bird **** off my hood with the clay but it didn’t seem to work. I’ll have to probably polish it out -____-
Clay alone won't do it. The clay will remove the containmanents but if its etched, you'll need to break out the machine and maybe even sand paper.
Yeah there’s this one spot that I’ve tried everything. I just bought a polisher and some new pads so hopefully that’ll work. It definitely helped a little, but now where I want it to be. Thanks though??
