shrktank Posted January 31, 2014 Share Posted January 31, 2014 Hello As a newbie I am learning that clay barring your car is highly encouraged and almost a necessity. I am ok with getting the product, but want to know the worst thing that can happen using the clay bar. Quote Link to comment Share on other sites More sharing options...
0 Tim Posted January 31, 2014 Share Posted January 31, 2014 (edited) The worst thing that can happen is you don't use enough lubrication and you mar your paint. Or, you drop the clay bar on the ground, it picks up stuff that scratches your paint because you didn't throw it out. Edited January 31, 2014 by Tim scootertrash19, 07RS4 and Green Machine 3 Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted February 1, 2014 Share Posted February 1, 2014 You run out of DS.......... seriously claying is easy and safe process. Green Machine 1 Quote Link to comment Share on other sites More sharing options...
0 Rich Posted February 1, 2014 Share Posted February 1, 2014 There's nothing to claying. It's about as simple as you can get. If you don't have detail spray, you can use soap and water, just be sure to keep your area well lubricated. And like Tim said.......DON'T DROP IT! Quote Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted February 1, 2014 Share Posted February 1, 2014 Dropping it is really the worst thing that can happen. Or buying cheap clay that can suck to, the new Adams bars are great. Quote Link to comment Share on other sites More sharing options...
0 LFairbanks Posted February 1, 2014 Share Posted February 1, 2014 The worst thing to happen like others have mentioned is dropping it. Other than that, once you try one you will find yourself ordering more bars. Quote Link to comment Share on other sites More sharing options...
0 6inarow Posted February 2, 2014 Share Posted February 2, 2014 how do you tell when the clay bar is contaminated enough to throw it out? does it wear out? Quote Link to comment Share on other sites More sharing options...
0 Performance Auto Detailing Posted February 2, 2014 Share Posted February 2, 2014 how do you tell when the clay bar is contaminated enough to throw it out? does it wear out? If you can't find a clean spot in the clay after kneading and folding it, it's time to throw it out. Quote Link to comment Share on other sites More sharing options...
0 Beemer Posted February 2, 2014 Share Posted February 2, 2014 Also - it kinda starts to fall apart. I know a lot of guys here clay multiple cars and reuse the clay. I just have one car I care for and toss the piece of clay after I use it. Since I only clay once or twice a year it's better for me. Quote Link to comment Share on other sites More sharing options...
0 mdolandese Posted February 2, 2014 Share Posted February 2, 2014 Remember to do the baggie test when your done to make sure it's good enough. Good luck and welcome to the forum Quote Link to comment Share on other sites More sharing options...
0 07RS4 Posted February 2, 2014 Share Posted February 2, 2014 (edited) A little tip I've been using forever...fill your clay tub with HOT water, the clay will be like butter and much more pliable around body lines, and also helps with the needing and folding. Like others have stated, pretty straight forward process. My son helps me clay vehicles sometimes, just don't drop it. Edited February 2, 2014 by 07RS4 Quote Link to comment Share on other sites More sharing options...
0 ksell87 Posted February 3, 2014 Share Posted February 3, 2014 A little tip I've been using forever...fill your clay tub with HOT water, the clay will be like butter and much more pliable around body lines, and also helps with the needing and folding. Interesting tip. Thanks! Claying just feels good once it's done. If you do the baggie test before and after and can notice the difference, it's really worth it. Quote Link to comment Share on other sites More sharing options...
0 Chuckster Posted February 4, 2014 Share Posted February 4, 2014 The worst thing about using a clay bar is: Once you are done claying the paint you will get addicted to the smoothness and then you will spend a ton of money on Adams products...... Highly addicting! Quote Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted February 7, 2014 Share Posted February 7, 2014 Claying is like exfoliating for your paint, most important step before polishing or sealing but often gets rushed or overlooked. Take your time, worst thing that happens is not enough lube and you have some light marring which will come out with a light polish anyway. The DUMBEST THING you can do is drop it and say "looks fine" and reuse on your paint. If you drop, throw it out, no questions asked. Quote Link to comment Share on other sites More sharing options...
0 icedaccord19 Posted February 11, 2014 Share Posted February 11, 2014 are there any good clay lubricants that you can get locally....I really don't want to use my Detail spray if I don't have to Quote Link to comment Share on other sites More sharing options...
0 Baron_Von_Awesome Posted February 11, 2014 Share Posted February 11, 2014 are there any good clay lubricants that you can get locally....I really don't want to use my Detail spray if I don't have to Mix up some car wash soap in a sprayer Quote Link to comment Share on other sites More sharing options...
0 icedaccord19 Posted February 12, 2014 Share Posted February 12, 2014 Cool Thanks!! Quote Link to comment Share on other sites More sharing options...
0 rimz808 Posted March 3, 2014 Share Posted March 3, 2014 How long have you guys had your clay bar until you had to replace it due to normal wear and tear? Also, how are you guys storing it? I just put mine in a zip lock bag. Good idea? Quote Link to comment Share on other sites More sharing options...
0 SYMAWD Posted March 3, 2014 Share Posted March 3, 2014 (edited) How long have you guys had your clay bar until you had to replace it due to normal wear and tear? Also, how are you guys storing it? I just put mine in a zip lock bag. Good idea? How long it lasts depends on how contaminated the cars you are working on are. If the clay becomes so dirty that you can't find a clean spot after kneading it, it is time for a new piece. Also, if the clay becomes really dry and breaks apart when you stretch it, you likely need a new piece. I store mine in the container it comes it with one mist of detail spray. Edited March 3, 2014 by SYMAWD Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted March 3, 2014 Share Posted March 3, 2014 I might add, don't seal up your clay in a baggie it could mildew. And that would be bad..... ArmyAcadia09 1 Quote Link to comment Share on other sites More sharing options...
0 Feets31 Posted March 3, 2014 Share Posted March 3, 2014 (edited) Do an area and then baggie test it. I did my entire car the first time and did a good job. The baggie test said differently. The second time I tested each section after doing it and had no problems. You have to put some pressure on it. Some on here do multiple cars with one clay bar. I use about 2/3 of one for one car. Use enough lubricant and throw away any you drop. Edited March 3, 2014 by Feets31 Quote Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted March 3, 2014 Share Posted March 3, 2014 I've been storing it in a plastic Baggie for 10 years now no mildew. Squeeze most air out, and mist it with detail spray so it doesn't dry out. I also keep it in the plastic tub the old Adams clay came in for a double seal. You replace it when it's visually dirty, no necessary time frame for wear and tear lol it's not brakes. Feets31 1 Quote Link to comment Share on other sites More sharing options...
0 Beemer Posted March 3, 2014 Share Posted March 3, 2014 I only have one car that I care for so my experience may not be typical but I think it is silly to save used clay. I break off enough to clay the car and store the unused clay, of course. But the used clay gets tossed after the car is finished. Saving it to reuse later seems a bit "Penny wise, pound foolish" to me. If I was doing multiple cars I might have a different opinion. Ricky Bobby 1 Quote Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted March 3, 2014 Share Posted March 3, 2014 I'm the same way, if I clay glass I just break a big enough piece to do it then toss it, ton of contaminants on glass. I usually will clay my car and my wife's car (regularly clayed so well maintained) twice a year, usually whatever piece I use after doing both cars gets tossed. I would use a piece about 75g or so for both cars, so in the Adam's 200g kit, I'd use 75g once on each car, and a 50 g piece once, maybe twice on glass. One Adam's clay bar kit gets me through about year and a half of claying. Quote Link to comment Share on other sites More sharing options...
0 Kingsford Posted March 4, 2014 Share Posted March 4, 2014 The worst thing that can happen is you don't use enough lubrication and you mar your paint. Or, you drop the clay bar on the ground, it picks up stuff that scratches your paint because you didn't throw it out. For the love of god if you drop it on the ground throw it away!!!! Pet Peeve! Quote Link to comment Share on other sites More sharing options...
shrktank
Hello
24 answers to this question
