LukeZimTDI Posted July 17, 2018 Share Posted July 17, 2018 So I got the Glass Sealant in my MB, what is it supposed to be applied with? Link to comment Share on other sites More sharing options...
1 BHarris23 Posted July 18, 2018 Share Posted July 18, 2018 1 hour ago, LukeZimTDI said: So I got the Glass Sealant in my MB, what is it supposed to be applied with? You can use a microfiber applicator or the small applicator like they use with the ceramic coating kits. Either one will work, but I would throw it in some APC solution after using so you don’t get any crystallization on the applicator. Link to comment Share on other sites More sharing options...
1 Mbrazelton Posted July 18, 2018 Share Posted July 18, 2018 I always use the Microfiber applicator. But I keep one just for Glass Sealant. Make sure to get the window good and clean before you seal it. Also for some reason, I feel like I get the window clean, and about 2 hours later I notice a spot with alittle haze. So I usually try to clean it the next do to. Link to comment Share on other sites More sharing options...
1 falcaineer Posted July 18, 2018 Share Posted July 18, 2018 Guys above have you covered, but sometimes seeing it helps... BrianT 1 Link to comment Share on other sites More sharing options...
1 RayS Posted July 18, 2018 Share Posted July 18, 2018 If you did not get any of the Glass Boost, it does make the Glass Sealant last longer. I also use the Glass Boost on the outside mirrors after I clean then with Glass Cleaner. I have found that using the Glass Boost on the mirrors cuts down on the headlight reflections at night and any overnight dew rolls off them easier. Rich 1 Link to comment Share on other sites More sharing options...
0 Editguy Posted July 23, 2018 Share Posted July 23, 2018 On 7/18/2018 at 6:20 AM, RayS said: If you did not get any of the Glass Boost, it does make the Glass Sealant last longer. I also use the Glass Boost on the outside mirrors after I clean then with Glass Cleaner. I have found that using the Glass Boost on the mirrors cuts down on the headlight reflections at night and any overnight dew rolls off them easier. I'll have to try that thanks! Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted July 23, 2018 Share Posted July 23, 2018 Just applied some fresh glass sealant last night, in time for it to rain, but got a great shot this morning from it. Love me some glass sealant! One thing is make sure the glass is CLEAN before applying it really helps, I quite often will use #0000 steel wool on my glass before application to ensure I get it spotless. LukeZimTDI, RayS, falcaineer and 2 others 5 Link to comment Share on other sites More sharing options...
0 rrmccabe Posted July 23, 2018 Share Posted July 23, 2018 Is that boost too or just sealant? Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted July 24, 2018 Share Posted July 24, 2018 1 hour ago, rrmccabe said: Is that boost too or just sealant? Just a fresh coat of sealant. I used #0000 steel wool and then cleaned good with glass cleaner prior to application. Applied with a great microfiber applicator vertical, horizontal, vertical again, let set for 3-4min ish and then buffed off with a blue glass towel that was lightly misted with glass cleaner. mc2hill and mexiking2365 2 Link to comment Share on other sites More sharing options...
0 Eric Leicht Posted July 26, 2018 Share Posted July 26, 2018 (edited) I dont have any Glass Boost at the moment, hoping to get some in 1 of the 8 mystery boxes on the way. A couple days ago I cleaned the windshield with GC then sealed with GS using a microfiber applicator pad. I took a spray bottle with just water in it and sprayed water on the windshield about an hour later and used H20 G&G to give it a little extra protection. Water runs like Usain Bolt off the windshield now. The GS is more than enough but hey, why not throw some more at it right? I clayed all the windows and polished them using my SK 12mm MIni 2 months ago and that made a huge difference with the GS curing to the window and lasting longer. Edited July 26, 2018 by Eric Leicht ZMAN024 1 Link to comment Share on other sites More sharing options...
0 wely324 Posted August 10, 2018 Share Posted August 10, 2018 I love glass sealant and also love topping the windows with h2o, it's a great combo. Eric Leicht 1 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted August 11, 2018 Share Posted August 11, 2018 @wely324 want a really quick and easy one.....try them with Brilliant Glaze. Doesnt last long but you get a great clean look and it beads like mad for....about the drive home lol. wely324 1 Link to comment Share on other sites More sharing options...
0 imatt27 Posted August 11, 2018 Share Posted August 11, 2018 FDF0227A-871C-4AEA-AA61-730C29CCA705.MOV Link to comment Share on other sites More sharing options...
0 wely324 Posted August 11, 2018 Share Posted August 11, 2018 3 hours ago, pirahnah3 said: @wely324 want a really quick and easy one.....try them with Brilliant Glaze. Doesnt last long but you get a great clean look and it beads like mad for....about the drive home lol. Yup, I tried and loved it, I love brilliant glaze on almost anything but plastic. Just wish it lasted longer, regardless the shine is worth it. Link to comment Share on other sites More sharing options...
0 Rich Posted August 11, 2018 Share Posted August 11, 2018 I use the Brilliant Glaze on the inside of my windows, Glass Sealant and boost on the outside. I very seldom have to use my wipers. Only bad thing is I have water sensitive wipers that come on automatically, other wise, I probably wouldn't have to use the wipers at all!! RayS 1 Link to comment Share on other sites More sharing options...
0 pirahnah3 Posted August 11, 2018 Share Posted August 11, 2018 Rich, I think you can turn those off. I know my Chally came with them and in the settings there was a way to shut them off, which I promptly did as I do not like the car telling me when to use them. Link to comment Share on other sites More sharing options...
0 DF24 Posted November 15, 2018 Share Posted November 15, 2018 Has any one attempted to apply Adam’s liquid paint sealant on glass and see if it works? Link to comment Share on other sites More sharing options...
0 Nickfire20 Posted November 15, 2018 Share Posted November 15, 2018 4 hours ago, DF24 said: Has any one attempted to apply Adam’s liquid paint sealant on glass and see if it works? Yea, it works fine. Not sure how long it held up, couple months maybe, it was my parents car, and I was wizzing through it. I normally use glass sealant, boost, and GnG. DS works fine at maintaining hydrophobic properties as well. DF24 1 Link to comment Share on other sites More sharing options...
0 DF24 Posted November 15, 2018 Share Posted November 15, 2018 1 hour ago, Nickfire20 said: Yea, it works fine. Not sure how long it held up, couple months maybe, it was my parents car, and I was wizzing through it. I normally use glass sealant, boost, and GnG. DS works fine at maintaining hydrophobic properties as well. Awesome thanks Link to comment Share on other sites More sharing options...
LukeZimTDI
18 answers to this question
